Learn how to integrate Flexi Funnels and MailerLite using Pabbly Connect in this detailed tutorial. Automate your email marketing effortlessly! Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect to Start Integration
To integrate Flexi Funnels and MailerLite, you first need to access Pabbly Connect. Visit the Pabbly Connect homepage by entering the URL in your browser. Once there, you can either sign in if you are an existing user or click on ‘Sign Up Free’ if you are new to the platform.
After logging in, you’ll be directed to the Pabbly Connect dashboard. Here, you will see all available applications. To create a new integration, click on the ‘Create Workflow’ button located at the top right corner. This will allow you to set up a new workflow to automate the process between Flexi Funnels and MailerLite.
In this step, you will create a workflow that connects Flexi Funnels to MailerLite using Pabbly Connect. After clicking the ‘Create Workflow’ button, a dialog box will appear. Here, name your workflow something descriptive, such as ‘Create MailerLite Subscriber on Flexi Funnels Form Submission’. You can also select a folder for your workflow.
  • Name your workflow appropriately to reflect its purpose.
  • Choose a folder to organize your workflows.
Once you’ve named your workflow and selected a folder, click on the ‘Create’ button. This will take you to the workflow setup page where you can define the trigger and action for your automation.
3. Setting Up the Trigger with Flexi Funnels
The next step involves setting up the trigger for your workflow using Pabbly Connect. Select Flexi Funnels as your trigger application. Then, choose the trigger event as ‘New Form Submission’. This means that every time a new form submission is made in Flexi Funnels, it will trigger the workflow.
Upon selecting the trigger, Pabbly Connect will provide you with a Webhook URL. Copy this URL and head over to your Flexi Funnels account. Go to the specific project and edit the form where you want to set up the webhook. Under the settings for your form, navigate to the integrations section and paste the Webhook URL into the designated field.
4. Setting Up the Action with MailerLite
Now that your trigger is set, you will set up the action using Pabbly Connect. Select MailerLite as your action application and choose the action event as ‘Create or Update Subscriber’. This ensures that every new form submission will automatically create a subscriber in your MailerLite account.
To connect your MailerLite account, you will need an API token. Log into your MailerLite account, go to the integrations section, and generate a new API token. Once you have this token, return to Pabbly Connect and paste the token in the required field. After connecting, map the fields from your Flexi Funnels form to the corresponding fields in MailerLite, such as email and name.
  • Select the ‘Create or Update Subscriber’ action in MailerLite.
  • Map the subscriber’s email and name from the Flexi Funnels form.
Once all fields are mapped correctly, click on the ‘Save and Send Test Request’ button. This will send a test request to MailerLite, confirming that the integration works as intended.
After setting up the workflow, it’s crucial to test the integration using Pabbly Connect. Go back to your Flexi Funnels form and submit a test entry with dummy data. This will allow you to see if the data flows correctly from Flexi Funnels to MailerLite.
Once you submit the test form, check your MailerLite account to verify that the new subscriber has been added with the correct details. If everything is set up properly, you should see the new subscriber appear in your MailerLite list. This confirms that your integration is working seamlessly.
In summary, using Pabbly Connect simplifies the process of integrating Flexi Funnels and MailerLite. You can now automate subscriber management without manual entry, allowing you to focus on growing your online course.
This tutorial demonstrated how to integrate Flexi Funnels with MailerLite using Pabbly Connect. By following these steps, you can automate your email marketing and enhance your engagement with students effortlessly. Enjoy the benefits of seamless integration!
