Learn how to integrate Facebook Lead Ads with Campaign Monitor using Pabbly Connect to automate subscriber creation seamlessly. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Accessing Pabbly Connect to Start Integration
To begin integrating Facebook Lead Ads with Campaign Monitor, you need to access Pabbly Connect. Open a new tab and enter the URL Pabbly.com/connect. This will take you to the Pabbly Connect landing page where you can sign up or log in.
If you’re a new user, click on ‘Sign up for free’ to create your account. Existing users can simply log in. Once logged in, navigate to the ‘All Apps’ section and click on ‘Access Now’ under Pabbly Connect to reach the dashboard where you can create workflows.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ option located at the top right corner. You will be prompted to name your workflow. Enter a descriptive name like ‘Add Subscribers to Campaign Monitor from Facebook Lead Ads’ and click on ‘Create’. using Pabbly Connect
Upon creating the workflow, you will see two sections: Trigger and Action. Here, you will set Facebook Lead Ads as your trigger application and Campaign Monitor as your action application. This means that every time a new lead is generated on Facebook, a new subscriber will automatically be created in Campaign Monitor.
  • Click on ‘Create Workflow’.
  • Select Trigger and Action applications.
Now that your workflow is set up, you can proceed to configure the trigger.
3. Configuring Facebook Lead Ads as Trigger Application
To set up the trigger, select ‘Facebook Lead Ads’ as your trigger application in Pabbly Connect. Next, choose the trigger event, which is ‘New Lead Instant’. Click on ‘Connect’ to establish a connection.
You’ll need to authorize the connection with your Facebook account. Ensure you are logged in to Facebook before proceeding. Once connected, select the Facebook page where your lead ad is running and choose the lead generation form you want to use. After selecting your options, click on ‘Save and Send Test Request’ to capture lead details.
  • Select ‘Facebook Lead Ads’ as your trigger.
  • Choose the ‘New Lead Instant’ event.
  • Connect to your Facebook account and select the page and form.
After testing, you should see the lead details captured in Pabbly Connect, confirming that your trigger is set up correctly.
4. Setting Up Campaign Monitor as Action Application
Now that the trigger is configured, it’s time to set up the action application. Select ‘Campaign Monitor’ as your action application in Pabbly Connect. Choose the action event as ‘Add Subscriber’ and click on ‘Connect’.
To connect to Campaign Monitor, you will need your API key. You can find this in your Campaign Monitor account under Account Settings. Copy the API key and paste it into the appropriate field in Pabbly Connect, leaving the password field blank. Click on ‘Save’ to connect.
Select ‘Campaign Monitor’ as your action. Choose the ‘Add Subscriber’ action event. Enter your API key and connect.
Once connected, map the fields from the Facebook Lead Ads submission to the Campaign Monitor fields. This ensures that the correct information is sent to create the subscriber.
After mapping the fields, click on ‘Save and Send Test Request’ to finalize the setup. You should receive a positive response indicating that the subscriber has been successfully added to your Campaign Monitor account.
To verify, log in to your Campaign Monitor account and check the subscribers list for the list you selected. You should see the new subscriber created with the details submitted from the Facebook Lead Ads form.
This successful integration showcases how Pabbly Connect can automate the process of adding subscribers from Facebook Lead Ads to Campaign Monitor. By following these steps, you can ensure a seamless connection between these two applications.
In this tutorial, we explored how to integrate Facebook Lead Ads with Campaign Monitor using Pabbly Connect. This integration automates subscriber creation, making it efficient and effective for managing leads. By following the outlined steps, you can easily set up this automation for your campaigns.
