Learn how to integrate Elementor with WhatsApp for lead notifications using Pabbly Connect. Follow our detailed tutorial for seamless automation. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start integrating Elementor with WhatsApp, you need to access Pabbly Connect. Open your browser and type in the URL for Pabbly Connect to reach the homepage. Here, you can either sign in to your existing account or sign up for a new account to enjoy 100 free tasks every month.
Once you log in, you will be directed to the dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ option. This is where the integration process begins, allowing you to automate the sending and receiving of WhatsApp messages whenever a form is submitted through Elementor.
2. Creating a Workflow in Pabbly Connect for Elementor
After accessing Pabbly Connect, the next step is to create a workflow specifically for Elementor form submissions. Click on the ‘Create Workflow’ button and name your workflow, such as ‘Send and Get WhatsApp Message on Elementor Form Submission’. Select the appropriate folder for better organization.
  • Name your workflow clearly for easy identification.
  • Select a folder to organize your workflows efficiently.
  • Click on ‘Create’ to finalize your workflow setup.
Once the workflow is created, you will see options for selecting a trigger and an action. The trigger will be the Elementor form submission, which will initiate the workflow, and the action will be sending messages via WhatsApp using AiSensy through Pabbly Connect.
3. Setting Up Elementor as the Trigger in Pabbly Connect
To set up the Elementor trigger in Pabbly Connect, select Elementor as the trigger application. Next, choose the trigger event as ‘New Form Submission’. This will ensure that every time a lead submits the form, the workflow is activated.
To connect Elementor with Pabbly Connect, you will receive a webhook URL. Copy this URL and navigate to your Elementor form settings. Under the ‘Actions After Submit’ section, add a webhook and paste the copied URL. This establishes a connection between Elementor and Pabbly Connect, allowing for automatic data transfer.
4. Sending WhatsApp Messages Using AiSensy via Pabbly Connect
After setting up the trigger, the next step is to configure the action to send WhatsApp messages via AiSensy. In your workflow, select AiSensy as the action application and choose the action event as ‘Send Template Message’. This action will facilitate sending messages to leads who submit the form. using Pabbly Connect
  • Provide the API key from your AiSensy account to establish the connection.
  • Create a campaign in AiSensy and link it with a template message.
  • Map the variables from the Elementor form to personalize the message.
Once these steps are completed, click on ‘Save and Send Test Request’ to verify that the messages are being sent correctly. If successful, you will receive a confirmation that the message has been sent to the lead’s WhatsApp.
5. Conclusion
In this tutorial, we have successfully set up an integration between Elementor and WhatsApp using Pabbly Connect. This automation allows you to send and receive WhatsApp messages seamlessly whenever a lead submits an inquiry form. By utilizing Pabbly Connect, you can enhance your lead management process without any coding skills.
Automating communications not only saves time but also ensures that no lead goes unnoticed, helping you convert inquiries into customers efficiently. Start using Pabbly Connect today to streamline your business communications!
