Learn how to integrate Elementor with Notion using Pabbly Connect to streamline your lead management process effectively. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
Setting Up Pabbly Connect for Elementor and Notion Integration
To begin the integration process, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website and either sign in or create a new account. If you’re a new user, you can sign up for free and enjoy a $1 discount every month.
Once signed in, navigate to your dashboard. Here, you will find an option to create a new workflow. Click on the ‘Create Workflow’ button, and give your workflow a name, such as ‘Elementor to Notion Integration’. After naming your workflow, click ‘Create’ to proceed to the workflow window.
Selecting Elementor as the Trigger Application in Pabbly Connect
In your newly created workflow, the next step is to set up a trigger. The trigger is the event that starts the workflow. For this integration, you will select Pabbly Connect as your trigger application and choose Elementor as the specific application to monitor for new form submissions.
After selecting Elementor, you will be prompted to choose a trigger event. Here, you should select ‘New Form Submission’ as the event that will trigger your workflow. Once selected, Pabbly Connect will provide you with a Webhook URL. Copy this URL, as it will be used to connect Elementor to Pabbly Connect.
Configuring Elementor to Send Data to Pabbly Connect
Now that you have your Webhook URL from Pabbly Connect, you need to configure Elementor. Log in to your WordPress account and navigate to the Elementor form you wish to connect. Click on ‘Edit with Elementor’ to open the form settings.
In the form settings, scroll down to the ‘Actions After Submit’ section. Here, you will add a new action by selecting ‘Webhook’. Once added, paste the Webhook URL you copied from Pabbly Connect into the designated field. Finally, make sure to click the ‘Publish’ button to save your changes.
Testing Your Integration with Pabbly Connect
With the Webhook URL configured in Elementor, it’s time to test the integration. Go back to your Elementor form and submit a test entry. Fill in the required fields, such as first name, last name, email, phone number, and property type, then click ‘Send’. This will send the test data to your Pabbly Connect workflow.
After submitting the form, return to Pabbly Connect and check if the Webhook has captured the response. You should see all the details you entered in the test submission. This confirms that the trigger is working correctly, and data is being sent from Elementor to Pabbly Connect.
Adding Submitted Data to Notion Using Pabbly Connect
Now that your Elementor form is set up to send data to Pabbly Connect, it’s time to configure the action application, which is Notion. In the Pabbly Connect workflow, select Notion as your action application and choose the action event ‘Create Database Item’.
You will then need to connect your Notion account to Pabbly Connect. Click on ‘Connect’, and if you haven’t connected before, follow the prompts to grant Pabbly Connect the necessary permissions. Once connected, select the database in Notion where you want to add the new lead details.
Next, you will map the fields from your Elementor submission to the corresponding fields in your Notion database. This mapping allows Pabbly Connect to automatically insert data into your Notion database based on new submissions from Elementor. After mapping all required fields, click ‘Send Test Request’ to verify that the data is being sent correctly.
In this tutorial, we explored how to integrate Elementor with Notion using Pabbly Connect. By following these steps, you can automate the process of transferring lead data from Elementor forms directly into your Notion database, enhancing your lead management efficiency.
