Learn how to integrate Elementor with Keep using Pabbly Connect to automate contact updates seamlessly. Follow our detailed tutorial for step-by-step instructions. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To integrate Elementor with Keep, the first step is accessing Pabbly Connect. Begin by opening your web browser and searching for Pabbly Connect to reach its landing page.
If you do not have an account, click on the ‘Sign up for free’ button. This process takes only two minutes and provides you with 100 free tasks every month. If you already have an account, simply click on ‘Sign in’ to access your dashboard.
Once you’re logged into Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button, which will prompt you to name your workflow.
Choose a descriptive name, such as ‘Create or Update Keep Contact on Elementor Form Submission’. After naming your workflow, click on ‘Create’ to proceed to the workflow setup page.
  • Select ‘Create’ to move to the next step.
In the workflow setup, you will see two boxes labeled ‘Trigger’ and ‘Action’. The trigger is the event that starts the workflow, while the action is what happens as a result. Here, you will set up your trigger to respond to form submissions from Elementor.
For the trigger, search for ‘Elementor’ in the application list within Pabbly Connect. Select it as your trigger application, and then choose the trigger event as ‘New Form Submission’.
Next, you will need to connect Elementor with Pabbly Connect. This requires copying the webhook URL provided by Pabbly Connect and pasting it into your Elementor form settings. This webhook acts as a bridge between Elementor and Pabbly Connect.
  • Select ‘New Form Submission’ as your trigger event.
  • Copy the webhook URL from Pabbly Connect.
  • Paste the webhook URL in the Elementor form settings under ‘Actions After Submit’.
After setting up the trigger, return to Pabbly Connect to test if it’s waiting for a response from Elementor. This step ensures that your integration is correctly set up to receive form submissions.
With the trigger established, the next step is to set the action that will occur when a new form submission is received. In Pabbly Connect, search for ‘Keep’ as your action application and select ‘InfusionSoft by Keep’.
Select the action event as ‘Create/Update Contact’. This action will allow you to either create a new contact or update an existing contact in Keep based on the form submission details.
Choose ‘InfusionSoft by Keep’ as your action application. Select ‘Create/Update Contact’ as your action event. Connect your Keep account to Pabbly Connect.
Once connected, map the form submission fields from Elementor to the corresponding fields in Keep. This mapping ensures that the correct data is sent to Keep for each new submission.
5. Testing the Integration and Conclusion
After completing the mapping, it’s essential to test your integration. Fill out your Elementor form and submit it. Check Pabbly Connect to see if the response has been received. You should see all the details filled in the form, confirming that the integration is working.
Finally, verify in your Keep account that the contact has been created or updated with the new information. This confirms that your integration between Elementor and Keep using Pabbly Connect is successful.
In summary, you have set up a workflow in Pabbly Connect to automatically create or update contacts in Keep whenever a new form submission is received from Elementor. This automation saves time and ensures your email list is always up-to-date.
By following this tutorial, you can effectively integrate Elementor with Keep using Pabbly Connect to streamline your contact management process. This setup not only enhances your marketing efforts but also improves audience engagement through timely updates.
