Learn how to automate subscriber creation in Mailchimp from Clone form submissions using Pabbly Connect. Follow our detailed tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To begin integrating Clone and Mailchimp, you need to access Pabbly Connect. Start by signing up for a free account on the Pabbly Connect dashboard, which allows you to create workflows effortlessly.
Once logged in, click on the ‘Create Workflow’ button. Name your workflow, for example, ‘Clone to Mailchimp Automation’ and click on ‘Create’. This opens a new workflow with two main sections: the trigger and the action.
2. Configuring Trigger in Pabbly Connect
The next step is to set up the trigger in Pabbly Connect. In the trigger section, search for ‘Clone’ and select it as your app. Then, choose the trigger event as ‘Form Submitted’. This configuration allows Pabbly Connect to capture form submissions from Clone.
  • Select the ‘Form Submitted’ trigger event.
  • Copy the provided webhook URL from Pabbly Connect.
  • Go to your Clone account and navigate to Automations to set up a new workflow.
In Clone, create a new workflow and select ‘Form Submitted’ as the trigger. Paste the webhook URL into the designated field. This setup ensures that every submission made in Clone is sent directly to Pabbly Connect for processing.
3. Setting Up Action in Pabbly Connect
After configuring the trigger, the next step is to define the action in Pabbly Connect. In the action section, search for ‘Mailchimp’ and select it. Choose the action event as ‘Add New Subscriber’.
To connect your Mailchimp account, you will need the API key and data center ID. Obtain these by logging into your Mailchimp account, going to your profile, and selecting ‘Extras’ followed by ‘API Keys’. Generate a new API key and copy it into Pabbly Connect.
  • Enter your Mailchimp API key and data center ID in Pabbly Connect.
  • Select your audience list from Mailchimp to which subscribers will be added.
  • Map the email address and other fields from Clone to Mailchimp.
Once all fields are correctly mapped, click on ‘Save and Send Test Request’ to verify the integration. If successful, the subscriber should appear in your Mailchimp account.
4. Testing the Integration Workflow
Now that both the trigger and action are set up in Pabbly Connect, it’s time to test the integration. Make a test submission in your Clone form using example data. For instance, enter a name, email, and phone number.
After submitting the form, return to Pabbly Connect and check the trigger window. You should see the form submission data captured successfully. This confirms that the connection between Clone and Pabbly Connect is working as intended.
To finalize, check your Mailchimp account under the ‘All Contacts’ section. The test submission should now appear as a new subscriber. This step verifies that your automation workflow is functioning correctly, allowing seamless subscriber addition from Clone to Mailchimp.
In this tutorial, we explored how to integrate Clone and Mailchimp using Pabbly Connect. By following the steps outlined, you can automate subscriber management efficiently. This integration enhances your marketing efforts by ensuring that new leads from Clone are automatically added to your Mailchimp audience.
