Learn how to automate sharing new Click Funnels contacts with your team on Discord using Pabbly Connect. Follow this detailed tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Setting Up Pabbly Connect for Click Funnels Integration
To start using Pabbly Connect, first, log in to your account. If you don’t have an account, you can create a free one in just two minutes. Pabbly Connect allows you to automate the sharing of new Click Funnels contacts with your team on Discord.
Once logged in, navigate to the dashboard and click on the ‘Create Workflow’ button. You will be prompted to name your workflow. For this integration, name it ‘Share New Click Funnels Contact with Your Team on Discord.’ Select a folder for your workflow and click ‘Create’. This sets the stage for automating your lead-sharing process.
2. Configuring the Trigger from Click Funnels
The next step in this automation is to set up the trigger in Pabbly Connect. Choose Click Funnels as your application and select the trigger event as ‘New Contact Created.’ This event will initiate the automation whenever a new lead is generated through your Click Funnels form.
After selecting the trigger event, you will be provided with a webhook URL. Copy this URL as you will need it to connect Click Funnels to Pabbly Connect. Go to your Click Funnels dashboard, navigate to the settings of your funnel, and find the Webhooks section. Click on ‘Add New Endpoint’ and paste the copied URL. Name the endpoint and select the event type as ‘Contact Created’ before clicking ‘Create Endpoint’. This establishes a connection between Click Funnels and Pabbly Connect.
3. Testing the Connection Between Click Funnels and Pabbly Connect
Now that the webhook is set up, it’s time to test the connection. In Pabbly Connect, you will see that it is waiting for a response. To test this, create a new contact in Click Funnels. Fill out the form with dummy data and submit it. As soon as you do this, Pabbly Connect will capture the lead information and show it in the response section.
- Create a new contact in Click Funnels.
- Fill out the form with required details.
- Submit the form to trigger the webhook.
Once the contact is created, you should see the details appear in Pabbly Connect. This confirms that the integration is functioning correctly, and now every new lead will be captured automatically.
4. Sending Contact Information to Discord via Pabbly Connect
After confirming that Click Funnels is successfully integrated with Pabbly Connect, the next step is to send the captured contact information to your team on Discord. In Pabbly Connect, select Discord as the action application and choose the action event as ‘Send Channel Message.’ This action will send the lead details to a specified Discord channel.
To connect Discord, you will need to set up a webhook URL in your Discord server. Go to the server settings, find the integrations section, and create a new webhook. Copy the webhook URL and paste it back into Pabbly Connect. You can personalize the message that will be sent, including details like the lead’s name, email, and phone number.
5. Finalizing the Automation with Pabbly Connect
Finally, once all details are set, click on the button to send the message. If everything is configured correctly, you should receive a confirmation response in Pabbly Connect. This indicates that your message has been successfully sent to the Discord channel.
With this setup, every time a new lead is generated in Click Funnels, their information will be automatically shared in your Discord channel without any manual effort. This automation streamlines your communication and helps your team follow up with leads promptly.
By utilizing Pabbly Connect, you can seamlessly integrate various applications, enhancing your business automation. This tutorial has shown you how to connect Click Funnels with Discord effectively. Now you can focus on converting leads while Pabbly Connect takes care of the workflow!
