Learn how to seamlessly integrate Cashfree Payment with Mailgun using Pabbly Connect for automated email management. Follow our step-by-step tutorial for effortless setup. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To integrate Cashfree and Mailgun, you first need to access Pabbly Connect. This platform allows you to create workflows that automate tasks without any coding skills. Start by visiting the Pabbly Connect website and signing in to your account.
Once logged in, you will be directed to the dashboard where you can manage all your workflows. Click on the ‘Create Workflow’ button to initiate the integration process. This step is crucial for connecting Cashfree with Mailgun through Pabbly Connect.
Creating a Workflow for Cashfree and Mailgun
In this section, we will create a workflow that automatically adds a new member in Mailgun when a payment is received via Cashfree. This is done by selecting Cashfree as the trigger application in Pabbly Connect.
Follow these steps to set up your workflow:
- Click on ‘Create Workflow’ and name it ‘Create Mailgun Member on Cashfree Payment’.
- Select Cashfree as the trigger application.
- Choose the trigger event as ‘Payment Successful’.
After configuring the trigger, you will need to connect your Cashfree account to Pabbly Connect. This requires a webhook URL provided by Pabbly, which acts as a bridge between the two applications. Make sure to test the connection to ensure everything is set up correctly.
Setting Up Mailgun Action in Pabbly Connect
Once the trigger is set, the next step is to configure the action in Mailgun. This action will create a new member in your Mailgun account whenever a payment is processed through Cashfree. Select Mailgun as the action application in Pabbly Connect.
To set up the action, follow these steps:
- Choose ‘Add Member’ as the action event.
- Connect your Mailgun account using the API key.
- Map the necessary fields such as email address and name from the Cashfree response.
By mapping these fields, you ensure that every payment made via Cashfree results in a new member being created in Mailgun. This automation greatly enhances efficiency and reduces manual workload, showcasing the power of Pabbly Connect.
Testing the Integration Between Cashfree and Mailgun
Testing the integration is a vital step to ensure that your workflow works as intended. Once you have set up the trigger and action in Pabbly Connect, you can perform a test payment through Cashfree.
Here’s how to test your integration:
Make a test payment using the Cashfree payment form. Check the response in Pabbly Connect to confirm it captured the payment details. Log into your Mailgun account to verify if the new member was created successfully.
After testing, if everything works correctly, your integration is now live! This seamless connection between Cashfree and Mailgun through Pabbly Connect will automate your email management process effectively.
In this tutorial, we explored how to integrate Cashfree Payment with Mailgun using Pabbly Connect. This automation allows for the automatic creation of Mailgun members upon successful payments, streamlining your email management process. By following the specific steps outlined, you can enhance your operational efficiency significantly.
