Learn how to seamlessly integrate Blogger posts with LinkedIn using Pabbly Connect. Follow this step-by-step tutorial for effective automation. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To begin integrating Blogger and LinkedIn, first access Pabbly Connect. As a user, sign in to your account. If you are new, click on the ‘Sign Up for Free’ button to create an account and receive 100 free tasks monthly.
Once logged in, navigate to the ‘All Applications’ page and select Pabbly Connect. Click on ‘Access Now’ to reach your dashboard. This is where you will create your workflow for sharing Blogger posts on LinkedIn.
On your Pabbly Connect dashboard, click on the ‘Create Workflow’ button located in the right-hand corner. Name your workflow, for example, ‘Share Blogger Post on LinkedIn’. Choose an appropriate folder to save your workflow.
  • You will be directed to a screen where you can set up your trigger and action.
In this section, you will define the trigger application as Blogger and the action application as LinkedIn. This setup is crucial for the automation process facilitated by Pabbly Connect.
3. Defining Trigger and Action for Integration
Now, set Blogger as your trigger application. Select the trigger event as ‘New Post Added’. This means that every time a new post is created in Blogger, it will initiate the workflow.
Next, move to the action window and select LinkedIn as your action application. Choose the action event as ‘Share an Article or URL’. This configuration allows the new Blogger post to be shared on LinkedIn automatically.
Make sure to establish connections for both applications. Click on ‘Connect’ for Blogger and sign in with your Google account. Once connected, select the specific blog from your Blogger account to link with Pabbly Connect.
4. Mapping Data with Pabbly Connect’s Data Transformer
After successfully connecting Blogger, you will need to map the data to ensure the content is shared correctly. Click on ‘Add Action Step’ and search for ‘Data Transformer’. This tool will help strip HTML tags from the content you want to share.
  • Select the action event as ‘Strip HTML Tags’.
  • Map the response received from Blogger to extract the content.
After mapping the content, click on ‘Save and Send Test Request’ to verify that the HTML tags have been successfully removed, making the text ready for LinkedIn sharing through Pabbly Connect.
5. Finalizing the LinkedIn Post
With the data transformed, return to the action window to set up the LinkedIn connection. Click on ‘Connect’ again, and log in to your LinkedIn account to establish a secure connection.
Now, map the title and content fields using the responses from the previous steps. Ensure the visibility is set to Pabbly so that your post is visible to all LinkedIn users.
Finally, click on ‘Save and Send Test Request’ to complete the integration. Check your LinkedIn account to confirm that the Blogger post has been shared successfully. This seamless integration is made possible through Pabbly Connect, allowing for efficient content sharing between platforms.
Integrating Blogger posts with LinkedIn using Pabbly Connect streamlines your workflow and enhances your online presence. With the steps outlined above, you can automate the sharing of your content effectively, ensuring that your audience is always updated with your latest posts.
