Learn how to instantly send SendGrid emails from new BigCommerce orders using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To integrate BigCommerce with SendGrid, you first need to access Pabbly Connect. Start by signing into your Pabbly Connect account. If you don’t have an account, you can create a free one in just a few minutes.
Once logged in, navigate to the Pabbly Connect dashboard. This is where you will create a new workflow to connect BigCommerce and SendGrid. Ensure that you have both accounts ready for seamless integration.
In Pabbly Connect, you can create a new workflow to automate the process of sending emails via SendGrid when a new order is placed in BigCommerce. Click on the ‘Create Workflow’ button to begin.
  • Name your workflow appropriately, for example, ‘BigCommerce to SendGrid Integration’.
  • Select ‘BigCommerce’ as your trigger application.
  • Choose ‘New Order’ as the trigger event.
After setting up the trigger, click on the ‘Save and Continue’ button. This will allow you to configure the connection between BigCommerce and Pabbly Connect.
3. Connecting BigCommerce to Pabbly Connect
To connect BigCommerce, you will need to provide your BigCommerce store credentials. Click on the ‘Connect’ button to establish the connection. A pop-up will appear asking for your BigCommerce API credentials.
Enter the required details such as API key and store URL. Once you’ve entered your credentials, click on ‘Save’. This will allow Pabbly Connect to fetch new order data from your BigCommerce store.
4. Setting Up SendGrid in Pabbly Connect
After connecting BigCommerce, the next step is to set up SendGrid as the action application. Click on the ‘Add Action Step’ button and select SendGrid from the list of applications. using Pabbly Connect
  • Choose ‘Send Email’ as the action event.
  • Connect your SendGrid account by providing the API key.
  • Fill in the email details such as recipient, subject, and message body.
Click ‘Save and Continue’ to finalize the setup. This integration will now automatically send an email through SendGrid whenever a new order is created in BigCommerce.
5. Testing the Integration
After setting up the integration, it’s crucial to test it to ensure everything is working correctly. Go back to your Pabbly Connect dashboard and click on the ‘Test’ button.
Place a test order in your BigCommerce store. Once the order is placed, check your SendGrid account to see if the email has been sent successfully. This confirms that Pabbly Connect is functioning properly and the integration is complete.
Integrating BigCommerce with SendGrid using Pabbly Connect allows for seamless communication with customers through automated emails. This tutorial provided a step-by-step guide to set up the integration effectively. Enjoy the benefits of streamlined communication with your customers!
