Learn how to seamlessly integrate BigCommerce and Klaviyo using Pabbly Connect in this detailed tutorial. Follow the step-by-step process for effective automation. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start integrating BigCommerce with Klaviyo, the first step is to access Pabbly Connect. Open your web browser and enter the URL Pabbly.com/connect. This will take you to the Pabbly Connect landing page where you can either sign in or sign up for a new account. New users can enjoy 100 free tasks monthly by selecting the ‘Sign up for free’ option.
Once logged in, you will see all the applications offered by Pabbly. Click on ‘Access Now’ for Pabbly Connect. This leads you to the dashboard where you can create your first workflow. To initiate, click on the ‘Create Workflow’ button, which will prompt you to name your workflow for easy identification.
After clicking on ‘Create Workflow’, you will be prompted to name your workflow. For this integration, name it ‘Create and Add Klaviyo Subscriber Based on BigCommerce Product Order’. Then, click on ‘Create’ to proceed to the workflow window where you can set up your trigger and actions.
The trigger is crucial as it dictates when the workflow will activate. In this case, select BigCommerce as the trigger application and choose the event ‘New Order Created’. Click on ‘Connect’ to link your BigCommerce account with Pabbly Connect. If you haven’t previously connected your account, you will need to provide your API credentials, which can be obtained from your BigCommerce account settings.
  • Navigate to BigCommerce account settings.
  • Select API accounts and create a new API account.
  • Copy the Client ID, Access Token, and Store Hash Key.
After inputting these details, click on ‘Save’ to establish the connection. This allows Pabbly Connect to receive order data from your BigCommerce account whenever a new order is placed.
Testing Order Submission with Pabbly Connect
To ensure that Pabbly Connect is capturing the data correctly, perform a test order submission in your BigCommerce account. Add a product to your cart and proceed to checkout. Fill in the required billing information and complete the order.
Once the order is placed, return to your Pabbly Connect workflow and click on ‘Save and Send Test Request’. This will prompt Pabbly Connect to fetch the latest order details. You should see a confirmation that the data has been captured, including the order ID and customer details.
  • Verify the order ID and customer information.
  • Ensure that the workflow is triggered correctly.
  • Check for any errors in the response.
With the order data successfully captured, you can now move on to set up the next action in your workflow using Pabbly Connect.
Adding a Klaviyo Subscriber Using Pabbly Connect
The next step is to create a subscriber in Klaviyo based on the order details captured from BigCommerce. In your workflow, select Klaviyo as the action application and choose the event ‘Create Profile’. This will allow you to add the customer as a subscriber to your Klaviyo account.
Connect your Klaviyo account to Pabbly Connect by selecting ‘Add a New Connection’ if you haven’t done so already. You will need to provide the necessary API keys and permissions to allow Pabbly Connect to interact with Klaviyo. Once connected, map the customer details from the BigCommerce order to the fields required in Klaviyo.
Map the email address, first name, last name, and any other relevant details. Ensure all required fields are filled out to avoid errors. Click ‘Save and Send Test Request’ to create the profile.
After successfully creating the profile, you can check your Klaviyo account to confirm that the new subscriber has been added. This integration allows you to automate customer engagement effectively using Pabbly Connect.
Finalizing the Integration in Pabbly Connect
To complete the integration, you will want to add the subscriber to a specific list in Klaviyo. In your workflow, select Klaviyo again as the action application and choose the event ‘Add Profiles to List’. Connect your Klaviyo account if prompted, and select the list where you want to add the subscriber.
Map the profile ID from the previous step to ensure the subscriber is added correctly. Once everything is set up, click ‘Save and Send Test Request’. This will finalize the process, and you should see a confirmation that the subscriber has been added to the list.
With this final action, you have successfully integrated BigCommerce and Klaviyo through Pabbly Connect. This automation will help streamline your email marketing efforts by ensuring that every new order results in a new subscriber being added to your targeted list.
In this tutorial, we explored how to integrate BigCommerce and Klaviyo using Pabbly Connect. By following the steps outlined, you can automate the process of adding new subscribers based on product orders, enhancing your marketing efficiency.
