Learn how to seamlessly integrate ActiveCampaign contacts to Pipedrive using Pabbly Connect with this step-by-step tutorial. No coding needed! Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start integrating ActiveCampaign with Pipedrive, you need to access Pabbly Connect. First, visit the Pabbly website and navigate to the products section. Select Pabbly Connect to begin the integration process.
Once on the Pabbly Connect dashboard, you can create a free account if you haven’t already. After signing in, you will be ready to create a new workflow for connecting ActiveCampaign to Pipedrive.
In this step, you will create a workflow in Pabbly Connect to automate the process of adding new contacts. Click on the ‘Create Workflow’ button in the top right corner. Name your workflow something descriptive, like ‘ActiveCampaign to Pipedrive’ and click on create.
- Give your workflow a name.
- Select ActiveCampaign as the trigger app.
- Choose the trigger event as ‘Contact Added’.
Once you have set up the trigger, you will need to connect your ActiveCampaign account to Pabbly Connect by entering the API key and URL. This will allow Pabbly Connect to fetch contact data from ActiveCampaign.
3. Setting Up ActiveCampaign in Pabbly Connect
Now, you need to configure ActiveCampaign within Pabbly Connect. Go to your ActiveCampaign account and navigate to the settings. Click on ‘Developer’ to find your API URL and key. Copy these details to use in Pabbly Connect.
In Pabbly Connect, paste the API URL without the ‘http://’ part, and enter your API key. After saving this information, select the specific list in ActiveCampaign from which you want to add contacts.
- Access your ActiveCampaign settings.
- Copy the API URL and key.
- Select the appropriate list from ActiveCampaign.
This setup allows Pabbly Connect to capture new contacts added to your chosen ActiveCampaign list, preparing them for transfer to Pipedrive.
4. Connecting Pipedrive in Pabbly Connect
Next, you will configure Pipedrive in Pabbly Connect to create new contacts automatically. In the action window of your workflow, select Pipedrive as the action app. Choose the action event as ‘Create Person’.
To connect your Pipedrive account, you will need to enter your Pipedrive API token. Access your Pipedrive account, go to personal preferences, and find the API section to copy your token. Paste this into Pabbly Connect and save the connection.
Select Pipedrive as the action app. Choose ‘Create Person’ as the action event. Enter your Pipedrive API token.
With these steps, you enable Pabbly Connect to create new contacts in Pipedrive based on the data received from ActiveCampaign.
5. Testing the Integration
After setting up both applications within Pabbly Connect, it’s time to test the integration. Fill out the ActiveCampaign form with contact details and submit it. Pabbly Connect will capture this data and attempt to create a new person in Pipedrive.
Check your Pipedrive account to confirm that the new contact has been added successfully. You should see the contact details populated, including the name, email, and phone number. This confirms that the integration is functioning as intended.
By following these steps, you have successfully set up an automated workflow using Pabbly Connect to link ActiveCampaign and Pipedrive. This process can save you time and streamline your contact management.
In this tutorial, we explored how to automate the process of adding new ActiveCampaign contacts to Pipedrive using Pabbly Connect. By following these detailed steps, you can enhance your workflow efficiency and ensure seamless data transfer between applications.
