Learn how to automate article writing in bulk using Pabbly Connect with Google Sheets and OpenRouter. Step-by-step tutorial for seamless integration. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect for Article Automation
To automate the process of writing articles in bulk, you need to start by accessing Pabbly Connect. This platform is essential for integrating various applications like Google Sheets and OpenRouter.
First, sign in to your Pabbly Connect account. If you are a new user, you can sign up for free and get 100 tasks every month. Once logged in, navigate to the Pabbly Connect dashboard to create a new workflow.
In your Pabbly Connect dashboard, click on the ‘Create Workflow’ button. Name your workflow something relevant, such as ‘Write Articles in Bulk using OpenRouter Automation’. This naming will help you identify the workflow later.
Next, you will set up the trigger application. In this case, select Google Sheets as your trigger application. The trigger event should be set to ‘New or Updated Spreadsheet Row’. This means the workflow will activate whenever a new row is added or an existing one is updated.
  • Choose the trigger event: New or Updated Spreadsheet Row.
Once you have set up the trigger, a webhook URL will be provided. You will need this URL to connect Google Sheets to Pabbly Connect.
To connect Google Sheets with Pabbly Connect, open your Google Sheet containing the article titles. Ensure you have the Pabbly Connect Webhooks extension installed. If not, you can find it in the Google Workspace Marketplace.
After installing, go to ‘Extensions’ > ‘Pabbly Connect Webhooks’ > ‘Initial Setup’. Here, paste the webhook URL you copied from Pabbly Connect and specify the trigger column, which is usually the final data column where you will input your article titles.
  • Paste the webhook URL in the setup.
  • Select the trigger column (typically the last column).
Click on ‘Send Test’ to ensure data is sent correctly to Pabbly Connect. Once successful, click on ‘Submit’ to complete the configuration.
4. Generating Articles Using OpenRouter
After setting up Google Sheets, it’s time to generate article content. In your Pabbly Connect workflow, add OpenRouter as the action application. The action event should be set to ‘Create Chat Completions’.
To establish a connection, you will need to enter your OpenRouter API key. Go to your OpenRouter account, create a new key, and copy it. Back in Pabbly Connect, paste the key to connect.
Set OpenRouter as the action application. Use the ‘Create Chat Completions’ action event. Enter your OpenRouter API key to establish a connection.
Map the article title from the previous step to generate content. Click on ‘Save and Send Test Request’ to see the generated content. This content will now be used in the next steps.
5. Saving Generated Articles to Google Drive
Now that you have the article content, the next step is to save it to Google Drive. In your Pabbly Connect workflow, add Google Drive as another action application and select ‘Create File in a Specific Folder’ as the action event.
Connect your Google Drive account and choose the folder where you want to save the articles. Map the file name to the article title for easy identification. After setting the file type to ‘Document’, click on ‘Save and Send Test Request’ to create the file.
Add Google Drive as the action application. Select ‘Create File in a Specific Folder’ as your action event. Map the file name to the article title.
Once the document is created, you can update its content by mapping the generated article content from OpenRouter. This ensures that the article is saved with the correct information.
Using Pabbly Connect, you can automate the process of writing articles in bulk effortlessly. By integrating Google Sheets and OpenRouter, you can generate, save, and manage your articles efficiently. This workflow not only saves time but also enhances productivity.
