Learn how to integrate Google Sheets with WooCommerce for automatic product updates using Pabbly Connect. Follow our step-by-step tutorial for seamless automation. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Introduction to Pabbly Connect for Google Sheets and WooCommerce
Pabbly Connect serves as the central platform for integrating Google Sheets with WooCommerce. This integration allows you to automate the process of updating your WooCommerce products whenever a new row is added to your Google Sheets. This tutorial will guide you through setting up this automation step-by-step. using Pabbly Connect
To begin, access Pabbly Connect by visiting the Pabbly Connect homepage. You can sign in if you already have an account or create a new one. New users receive 100 free tasks each month to explore the platform. After signing in, you will be directed to the dashboard where you can create your workflows.
To create a new workflow, click on the ‘Create Workflow’ button on the top right corner of the dashboard. A dialog box will prompt you to name your workflow. Name it something descriptive, like ‘Update WooCommerce Product from Google Sheets’. After naming, choose a folder to save your workflow. using Pabbly Connect
  • Select Google Sheets as your trigger application.
  • Choose ‘New or Updated Spreadsheet Row’ as your trigger event.
Once the trigger is set, Pabbly Connect will provide you with a webhook URL. This URL facilitates the communication between Google Sheets and Pabbly Connect, enabling data transfer. Copy this webhook URL for the next steps.
3. Setting Up Google Sheets with Pabbly Connect
Open your Google Sheets document that contains your WooCommerce product details. To connect it with Pabbly Connect, navigate to the ‘Extensions’ menu, select ‘Add-ons’, and then click on ‘Get Add-ons’. Search for ‘Pabbly Connect Webhooks’ and install it if you haven’t done so already. using Pabbly Connect
  • After installation, refresh the Google Sheets page.
  • Go to ‘Extensions’ > ‘Pabbly Connect Webhooks’ > ‘Initial Setup’.
  • Paste the copied webhook URL into the appropriate field and set the trigger column.
For example, if your product image is in column E, set that as your trigger column. Click on ‘Send Test’ to verify the connection. Once the data is successfully sent, your Google Sheets will be integrated with Pabbly Connect.
4. Integrating WooCommerce with Pabbly Connect
With your Google Sheets now connected, it’s time to set up the WooCommerce integration. Return to Pabbly Connect and add an action step by selecting WooCommerce as the action application. Choose the action event ‘Update a Product’. using Pabbly Connect
Now, you will need to connect your WooCommerce account. Click on ‘Add New Connection’ and enter your WooCommerce website URL, consumer key, and consumer secret. These keys can be generated in your WooCommerce settings under the REST API section.
Make sure to grant read and write permissions when generating API keys. Map the necessary fields such as Product ID, Product Name, Regular Price, and Sale Price from the Google Sheets response. Click ‘Save and Send Test Request’ to update the product in WooCommerce.
Once the test request is successful, your WooCommerce product will reflect the updated details based on the information from your Google Sheets.
5. Testing the Automation with Pabbly Connect
To ensure everything is functioning correctly, add a new row to your Google Sheets with the details of a product you want to update or create. This should include the product name, ID, regular price, sale price, and image URL.
After entering the information, check your WooCommerce store to see if the product has been updated or created. If you added a product that doesn’t exist, it should be created automatically. If it already exists, it should be updated with the new details.
Verify that the product ID in your Google Sheets updates accordingly. Check for any errors in Pabbly Connect and adjust your workflow if necessary.
Once confirmed, your automation is now fully operational, allowing you to seamlessly manage product updates between Google Sheets and WooCommerce using Pabbly Connect.
By following this tutorial, you can effectively automate the process of updating WooCommerce products from Google Sheets using Pabbly Connect. This integration streamlines your workflow, saving you time and effort in managing your online store.
