Learn how to automate sharing Shopify products on your Facebook page using Pabbly Connect with this step-by-step tutorial. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Accessing Pabbly Connect for Shopify and Facebook Integration
To share Shopify products on your Facebook page, you will first need to access Pabbly Connect. This powerful automation tool allows you to connect various applications seamlessly. Start by visiting the Pabbly Connect homepage at Pabbly.com/connect.
Once there, you will see options to sign in or sign up. If you are a new user, click on ‘Sign Up Free’ to get started. Existing users can simply click ‘Sign In’ to access their dashboard. After logging in, you will be ready to create a new workflow for your Shopify and Facebook integration.
After signing in to Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard. In the dialog that appears, name your workflow, for example, ‘Share Shopify Product on Facebook Page,’ and select a folder for organization.
  • Click on ‘Create’ to start building your workflow.
  • You will see fields for setting up a trigger and action.
In the workflow window, begin by selecting a trigger application, which will be Shopify. Choose the trigger event as ‘New Product.’ This setup ensures that every time a new product is added to your Shopify store, Pabbly Connect will capture this event and initiate the subsequent actions.
3. Connecting Shopify with Pabbly Connect
To connect Shopify with Pabbly Connect, you will receive a webhook URL after setting up your trigger. Copy this URL and head to your Shopify account. Navigate to the ‘Settings’ section, then click on ‘Notifications’ and find the ‘Webhooks’ option.
  • Click on ‘Create Webhook’ and select the event as ‘Product Creation.’
  • Paste the webhook URL you copied from Pabbly Connect into the URL field.
Make sure to select ‘JSON’ as the format and use the latest API version. After filling out the required fields, click on ‘Save.’ This action establishes a connection between your Shopify account and Pabbly Connect, enabling it to receive notifications when new products are added.
4. Setting Up Facebook Page Integration in Pabbly Connect
Now that Shopify is connected to Pabbly Connect, the next step is to set up the action application, which will be your Facebook Page. In the action step, select Facebook Page and choose the action event as ‘Create a Page Photo Post.’
To connect your Facebook Page, click on ‘Connect’ and follow the prompts to authorize Pabbly Connect to access your Facebook account. Once connected, select the Facebook Page where you want the product posts to appear.
Map the data from the trigger step to the Facebook post fields. For example, use the photo URL and title from the Shopify product details. This mapping ensures that whenever a new product is created, the relevant details are automatically populated in the Facebook post.
After setting up the integration, it’s crucial to test it. Go back to your Shopify account and create a new product. Once the product is saved, Pabbly Connect should receive the webhook response and trigger the action to create a new post on your Facebook Page.
Check your Facebook Page to verify that the new product post appears correctly. It should include the title and a description like ‘New Product Alert: [Product Title] – Go and grab yours now!’ This confirms that the integration is working as intended.
With this setup, you have successfully automated the sharing of your Shopify products on your Facebook page using Pabbly Connect. This integration not only saves time but also enhances your marketing efforts by keeping your followers updated with new product launches.
In conclusion, using Pabbly Connect to share Shopify products on your Facebook page automates your marketing process effectively. By following these steps, you can ensure that your followers are always informed about new products, boosting engagement and sales.
