Learn how to share Instagram posts to WordPress seamlessly using Pabbly Connect. Step-by-step tutorial for effective integration with images. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
1. Accessing Pabbly Connect for Instagram to WordPress Integration
To share Instagram posts to WordPress, you must first access Pabbly Connect. Start by typing ‘Pabbly.com/c/connect’ in your browser. This will take you to the Pabbly Connect homepage where you can sign in or sign up for free.
If you are a new user, click on the ‘Sign up for free’ button to create an account and receive 100 free tasks every month. Existing users can simply sign in. Once logged in, navigate to the ‘All Applications’ page and select Pabbly Connect to access your dashboard.
In your Pabbly Connect dashboard, click on the ‘Create Workflow’ button located in the top right corner. You will be prompted to name your workflow; for this tutorial, name it ‘Share Instagram Post to WordPress with Images’.
- Choose a folder to save the workflow, such as ‘Instagram to WordPress Automation’.
- Click ‘Create’ to proceed to the trigger and action setup.
Now you are on a critical window to set up your trigger and action. The trigger application will be Instagram, and the action application will be WordPress, enabling the automation process using Pabbly Connect.
3. Setting Up Instagram Trigger in Pabbly Connect
To set up your trigger, select ‘Instagram for Business’ as the trigger application. The trigger event should be set to ‘New Media Posted’. This event will monitor your Instagram account for any new posts.
Next, click on ‘Connect’ to establish a connection between your Instagram account and Pabbly Connect. You will be prompted to authorize the connection. Once authorized, Pabbly Connect will fetch the latest media from your Instagram account every 10 minutes.
4. Setting Up WordPress Action in Pabbly Connect
After setting up the Instagram trigger, it’s time to configure the action. Select ‘WordPress’ as the action application and choose ‘Create a New Post’ as the action event. This will allow Pabbly Connect to create a new post on your WordPress site whenever a new Instagram post is made.
To establish the connection, click on ‘Connect’ and enter your WordPress username, password, and base URL. For the base URL, navigate to your WordPress account to copy it. Once all details are entered, click ‘Save’. This connects your WordPress account to Pabbly Connect.
- Ensure that the post type is set to ‘Post’.
- Map the post title and content from the Instagram response.
By mapping these fields correctly, Pabbly Connect ensures that every new Instagram post is accurately reflected in your WordPress account.
5. Testing the Automation with Pabbly Connect
With the trigger and action set up, it’s time to test the automation. Create a new post on your Instagram account and include an image. After posting, return to Pabbly Connect and click on ‘Save and Send Test Request’. This will fetch the latest Instagram post details.
Once the test request is successful, you should see the new post details, including the image URL and caption. Finally, check your WordPress account to confirm that the post has been created successfully. This demonstrates how Pabbly Connect effectively automates sharing Instagram posts to WordPress.
In this tutorial, we explored how to share Instagram posts to WordPress using Pabbly Connect. By following these steps, you can automate your posting process, ensuring that your Instagram content reaches your WordPress audience seamlessly. Enjoy the benefits of this integration!
