Learn how to automate sharing Instagram posts to Discord using Pabbly Connect. This tutorial covers step-by-step integration for seamless automation. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Setting Up Pabbly Connect for Instagram and Discord Integration
To begin automating the sharing of Instagram posts to Discord, you need to access Pabbly Connect. Start by signing up for a free account on the Pabbly Connect website. Once you have signed up, log in to reach the dashboard where you can create your workflow.
In the dashboard, click on the ‘Create Workflow’ button. You can name your workflow appropriately, such as ‘Instagram to Discord Automation’. After naming your workflow, click on the ‘Create’ button to proceed to the workflow page.
2. Defining Trigger and Action in Pabbly Connect
In this step, you will define the trigger and action for your automation in Pabbly Connect. The trigger event will be when a new media post is published on Instagram. Click on the dropdown to choose Instagram as your trigger application.
  • Select ‘New Media Posted in My Account’ as the trigger event.
  • Click on the ‘Connect’ button and choose ‘Add New Connection’.
  • Authorize Pabbly Connect to access your Instagram account.
Once you have authorized the connection, click on ‘Save and Send Test Request’ to fetch the latest post data from your Instagram account. This will include the username, post link, caption, and media URL, which are essential for the next steps.
3. Connecting Discord to Pabbly Connect
Now that you have set up the trigger, it’s time to connect Discord for the action part of the automation. In the action section of Pabbly Connect, search for Discord and select it as the action application.
Choose the action event as ‘Send Channel Message’. You will need to connect your Discord account by clicking on the ‘Connect’ button. Once connected, you will be prompted to enter the webhook URL from your Discord server.
  • Access your Discord server settings and create a new webhook.
  • Select the channel where you want the messages to be sent.
  • Copy the webhook URL and paste it into Pabbly Connect.
After entering the webhook URL, you can customize the message that will be sent to your Discord channel. Use dynamic fields from the Instagram trigger to include the post link in your message.
4. Testing the Automation with Pabbly Connect
With everything set up, it’s time to test your automation in Pabbly Connect. Click on ‘Save and Send Test Request’ to send a test message to your Discord channel. Ensure that the message reflects the content you set up, including the Instagram post link.
Check your Discord channel to confirm that the message was received correctly. If the test is successful, your automation is ready to go. This means every time you post on Instagram, it will automatically share to your Discord channel without any manual effort.
5. Conclusion: Seamless Instagram to Discord Sharing with Pabbly Connect
By following these steps, you can successfully automate the process of sharing Instagram posts to Discord using Pabbly Connect. This integration enhances your productivity, allowing you to engage with your Discord community effortlessly.
Now, every time you publish a new post on Instagram, it will be shared automatically in your chosen Discord channel, helping you grow your audience and maintain engagement.
This tutorial has provided a clear and detailed guide on how to use Pabbly Connect for Instagram and Discord integration. Enjoy automating your social media sharing!
