Learn how to automate sharing Blogger posts on X using Pabbly Connect. Follow this detailed tutorial to set up your integration seamlessly. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start sharing Blogger posts on X, first access Pabbly Connect. This platform automates the process by connecting different applications seamlessly. You can visit Pabbly Connect by browsing the URL Pabbly.com/slc/connect.
Once on the homepage, you will see options to either sign in or sign up. New users can click on sign up free to receive 300 tasks every month. Existing users should click on sign in to access their account.
After signing in, navigate to the Pabbly Connect dashboard. To create a new workflow, click on the create workflow button located at the top right corner. Name your workflow, such as Share Blogger Post on X, and select a folder for organization.
- Click on create to initiate the workflow.
- You will see a confirmation that the workflow has been created successfully.
In this workflow, you will set up a trigger and an action. The trigger will be from Blogger, and the action will be directed to X. This is how Pabbly Connect enables the automation of sharing posts efficiently.
3. Setting Up the Trigger with Blogger
To set up the trigger, select Blogger as the trigger application and choose new post added as the trigger event. Click on connect to link your Google Blogger account with Pabbly Connect.
- Choose add new connection to create a new link.
- Select sign in with Google and follow the prompts to authorize.
After successfully connecting, select your blog ID from the options provided. Ensure to set the state to only live to capture only published posts. This step is crucial for ensuring that Pabbly Connect functions correctly in monitoring your Blogger posts.
4. Setting Up the Action Step with X
Next, you will set the action application to X and select create a tweet as the action event. Click on connect to establish a link between your X account and Pabbly Connect.
You will need to enter your client ID and client secret from your Twitter developer account. Follow the instructions provided to generate these credentials.
Once you’ve entered the necessary details, click on save and authorize the app. Finally, customize the tweet message to include a link to your new post. This is how Pabbly Connect facilitates the sharing of your Blogger posts directly to X.
5. Testing the Integration
After setting up the workflow, it’s essential to test the integration. Create a new post in your Blogger account, ensuring it has a title and description. Publish the post and return to Pabbly Connect to save and send a test request.
Check your X account for the new tweet. It should display your message along with the link to the Blogger post. If successful, this confirms that Pabbly Connect is working correctly to automate the sharing process.
If you do not see the tweet immediately, remember that Blogger may take some time to reflect new posts in Pabbly Connect. However, once it updates, your automation will effectively share your Blogger posts on X.
This tutorial outlined how to automate sharing Blogger posts on X using Pabbly Connect. By following these steps, you can streamline your social media sharing process efficiently.
