Learn how to set up Razorpay automation for multiple products using Pabbly Connect. Follow this detailed tutorial for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Accessing Pabbly Connect for Razorpay Automation
To set up Razorpay automation for multiple products inside Pabbly Connect, start by accessing the Pabbly Connect dashboard. You can create a free account in just a few minutes by following the sign-up link provided in the description.
Once logged in, navigate to the dashboard and click on ‘Create Workflow’. Name your workflow, for instance, ‘Razorpay to Google Drive’. This will initiate the setup process for automating payment responses from Razorpay through Pabbly Connect.
2. Connecting Razorpay with Pabbly Connect
The next step involves connecting your Razorpay account to Pabbly Connect. In the trigger window, search for Razorpay and select it as your application. Choose the trigger event as ‘Payment Captured’ to initiate the automation process.
  • Select Razorpay as the app.
  • Choose ‘Payment Captured’ as the trigger event.
After copying the webhook URL, go to your Razorpay account and navigate to ‘Accounts and Settings’. Click on ‘Webhooks’ and add a new webhook using the copied URL, ensuring that the active event is set to ‘payment.captured’. This step is crucial for enabling Pabbly Connect to receive payment notifications from Razorpay.
3. Setting Up Payment Routes in Pabbly Connect
After successfully connecting Razorpay, you need to create routes within Pabbly Connect to handle different product payments. This is done using the Router feature. Click on ‘Add Router’ to create multiple routes based on the payment amount received.
For example, set up three routes for the different courses you offer, each with a unique payment amount:
  • Java course: 79900 (Rupees)
  • Python course: 99900 (Rupees)
  • PHP course: 49900 (Rupees)
Each route will be configured to check the payment amount and direct the workflow to share the corresponding course file from Google Drive using Pabbly Connect.
4. Sharing Course Files from Google Drive
Once the routes are established, the next step is to set the action for each route to share the appropriate course file. In the action step, select Google Drive and choose the action event as ‘Share a File’.
Connect your Google Drive account to Pabbly Connect by signing in and granting the necessary permissions. After connecting, select the specific course file you wish to share based on the payment received:
For the Java course, select ‘Java Course PDF’. For the Python course, select ‘Python Basics PDF’. For the PHP course, select ‘PHP Codes PDF’.
Map the email address of the customer from the Razorpay payment data to ensure that the course file is sent to the correct recipient. This integration allows for seamless file sharing directly through Pabbly Connect.
5. Testing Your Automation Workflow
With the workflow set up, it’s essential to test the automation to ensure everything functions as intended. You can do this by making test payments for each course using the Razorpay payment page.
After completing a test payment, check the email of the customer to verify that the correct course file was shared. For instance, if a payment of 99900 was received for the Python course, the corresponding file should be sent automatically:
Make a payment for the Java course. Make a payment for the Python course. Make a payment for the PHP course.
By running these tests, you can confirm that Pabbly Connect is effectively capturing payment details and sharing the appropriate files, ensuring a smooth customer experience.
Setting up Razorpay automation for multiple products using Pabbly Connect streamlines the payment and file-sharing process. This integration allows you to efficiently manage customer transactions and deliver course materials seamlessly.
