Learn how to set up a webhook inside Zoho Subscription using Pabbly Connect. Follow this detailed tutorial for seamless integration with Google Sheets and more.
1. Setting Up Pabbly Connect for Zoho Subscription
To integrate Zoho Subscription with other applications, first, access Pabbly Connect. This platform acts as the bridge for connecting various applications, allowing seamless data transfer.
Start by logging into your Pabbly Connect account. Once logged in, you will see the dashboard where you can set up your automation workflow. The first step is to select Zoho Subscription as your trigger application.
2. Selecting the Trigger Event in Pabbly Connect
In Pabbly Connect, after choosing Zoho Subscription, you need to select a trigger event. For this setup, choose the ‘New Subscription’ event. This event will initiate the workflow whenever a new subscriber is added.
  • Select ‘Zoho Subscription’ as the trigger application.
  • Choose ‘New Subscription’ as the trigger event.
  • Copy the provided webhook URL for later use.
After selecting the trigger event, you will receive a webhook URL. This URL is crucial as it connects Zoho Subscription with Pabbly Connect, allowing data to flow seamlessly between the two platforms.
3. Configuring Zoho Subscription with Webhook
Next, log into your Zoho Subscription account. Click on the gear icon to access settings, then navigate to the ‘Automation’ section. Here, you will find the option to set up webhooks.
Click on ‘Webhooks’ and then select the ‘New Webhook’ button. Give your webhook a name, such as ‘New Subscription’, and select the subscription module. Paste the copied webhook URL from Pabbly Connect into the designated field.
  • Name your webhook (e.g., New Subscription).
  • Select ‘Subscriptions’ as the module.
  • Paste the webhook URL from Pabbly Connect.
After configuring the webhook, save your settings. This setup ensures that whenever a new subscriber is added in Zoho Subscription, the data will be sent to Pabbly Connect automatically.
4. Testing the Integration Between Zoho Subscription and Pabbly Connect
To test the integration, go back to Pabbly Connect and click on the ‘Recapture Webhook Response’ button. This will allow you to see if the setup is working correctly.
Now, create a new subscriber in Zoho Subscription. After adding the subscriber, return to Pabbly Connect to check if the response has been captured successfully. You should see the event type indicating that a new subscription has been created.
Create a new customer in Zoho Subscription. Add the customer as a subscriber. Check Pabbly Connect for the captured response.
If the response shows the correct subscriber details, your integration is successful. This means that Pabbly Connect has effectively captured the new subscription event from Zoho Subscription.
5. Conclusion: Streamlining Your Workflow with Pabbly Connect
In conclusion, setting up a webhook inside Zoho Subscription using Pabbly Connect is a straightforward process. By following the steps outlined above, you can automate the transfer of subscriber information to other applications like Google Sheets.
This integration not only saves time but also enhances productivity by ensuring that all subscriber data is captured in real-time. With Pabbly Connect, you can easily connect various applications without the need for coding skills, making it accessible for everyone.
