Learn how to set up a webhook inside WebinarKit using Pabbly Connect. Follow our step-by-step tutorial to automate your webinar registrations effectively. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Access Pabbly Connect for Webhook Setup
To set up a webhook inside WebinarKit, first, access Pabbly Connect. This integration platform allows you to connect various applications seamlessly. Start by logging into your Pabbly Connect account.
After logging in, navigate to the dashboard where you can create a new workflow. This will be essential for setting up the webhook that connects with WebinarKit.
2. Configure Trigger for WebinarKit in Pabbly Connect
In this step, you will set up the trigger in Pabbly Connect for WebinarKit. Click on ‘Create Workflow’ and name it appropriately. Then, search for ‘WebinarKit’ as your trigger application.
- Select ‘New Webinar’ as the trigger event.
- After this, you will receive a webhook URL.
- This URL acts as a bridge to connect your WebinarKit account with Pabbly Connect.
Copy this webhook URL as it will be required to set up the webhook inside WebinarKit.
3. Set Up Webhook Inside WebinarKit
Now, navigate to your WebinarKit account. Here, you will set up the webhook using the URL you copied from Pabbly Connect. Go to the webinar settings and find the option to add a webhook.
Paste the copied webhook URL into the designated field. This action will allow WebinarKit to send registration details to Pabbly Connect automatically whenever a new registration occurs.
4. Test the Webhook Integration
After setting up the webhook, it is crucial to test the integration. Go back to Pabbly Connect and click on ‘Test Trigger’ to confirm that the webhook is working correctly. This will ensure that data is being sent correctly from WebinarKit.
To perform the test, submit a registration form in WebinarKit with dummy data. Check the response in Pabbly Connect to verify that the details have been captured successfully.
5. Finalize the Webhook Setup in Pabbly Connect
Once you have tested the integration successfully, you can finalize the setup. In Pabbly Connect, click on ‘Save’ to ensure all your configurations are stored. This means that your webhook is now fully functional.
Now, every time someone registers for a webinar, their details will be sent to Pabbly Connect, allowing you to manage and automate your webinar registrations effectively.
Setting up a webhook inside WebinarKit using Pabbly Connect is a straightforward process. By following the steps outlined, you can automate your webinar registration effectively, ensuring seamless data transfer between applications.
