Learn how to set up a webhook inside Voiceform using Pabbly Connect. This tutorial provides step-by-step instructions for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Setting Up Pabbly Connect for Voiceform Integration
To set up a webhook inside Voiceform, you will first need to access Pabbly Connect. This platform serves as the central hub for integrating various applications, including Voiceform. Begin by logging into your Pabbly Connect account.
Once logged in, navigate to the trigger window and search for Voiceform as your trigger application. The trigger event you will select is ‘form submission’. This event will initiate the workflow whenever a new form is submitted in your Voiceform account.
2. Copying the Webhook URL from Pabbly Connect
After selecting Voiceform as your trigger application, a webhook URL will be generated in Pabbly Connect. This URL is crucial as it acts as a bridge, connecting your Voiceform account with Pabbly Connect. Make sure to read the help desk instructions provided below the URL carefully.
- Locate the generated webhook URL in Pabbly Connect.
- Copy this URL as it will be used in your Voiceform settings.
Now, proceed to your Voiceform account. This is where you will paste the copied webhook URL to establish the connection. Ensure you have your Voiceform form ready for integration.
3. Configuring the Webhook in Voiceform
In your Voiceform account, navigate to the form you wish to integrate. Click on the ‘Connect’ tab, and then select ‘Webhooks’. Here, you will find an option to add a webhook.
Paste the webhook URL you copied from Pabbly Connect into the provided field and click on ‘Save Webhook’. This action activates the webhook, allowing Voiceform to send data to Pabbly Connect upon form submission.
- Select the form you want to integrate.
- Navigate to ‘Connect’ and choose ‘Webhooks’.
- Paste the webhook URL and save changes.
Now that the webhook is added, it will be activated, allowing for real-time data capture in Pabbly Connect whenever a new form submission occurs.
With the webhook successfully configured, it’s time to test the integration. Go back to Pabbly Connect, where you will see it is waiting for a webhook response. This indicates that the system is ready to capture data from your Voiceform.
To perform a test submission, return to your Voiceform form and fill out the required fields such as name, email, and phone number. After entering the details, submit the form. This action will trigger the webhook, sending the data to Pabbly Connect.
Upon successful submission, you should see a confirmation in Voiceform. Now, switch back to Pabbly Connect, where you will find the response details captured from the form submission. This will include the name, email, and phone number that were submitted.
5. Conclusion: Successful Webhook Setup with Pabbly Connect
In conclusion, you have successfully set up a webhook inside Voiceform using Pabbly Connect. This integration allows for seamless data transfer between Voiceform and other applications whenever a form is submitted. With Pabbly Connect, you can automate workflows and enhance your data management efficiency.
By following these steps, you can ensure that your Voiceform submissions are effectively captured and utilized within your desired applications. This setup not only streamlines your processes but also opens up possibilities for advanced automations.
