Learn how to set up a webhook inside Thinkific using Pabbly Connect to automate user data collection and integration with Google Sheets. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Setting Up Pabbly Connect for Thinkific Webhook
To set up a webhook inside Thinkific, we will utilize Pabbly Connect. This powerful integration platform allows you to automate workflows between Thinkific and other applications seamlessly. Start by logging into your Pabbly Connect account.
Once logged in, create a new workflow. Select Thinkific as your trigger application and choose the event that will initiate the webhook, such as ‘New User Signed Up.’ This event will allow you to capture user details whenever a new student enrolls in your course.
2. Configuring the Trigger in Thinkific
In this step, we will configure the trigger in Thinkific using Pabbly Connect. After selecting Thinkific as your trigger app, you will be prompted to choose a trigger event. For our integration, select ‘Enrollment Created’ as the trigger event.
  • Log into your Thinkific account.
  • Navigate to the Development section in the dashboard.
  • Select the Webhooks option under Code and Analytics.
After selecting the trigger event, Pabbly Connect will provide you with a webhook URL. This URL is crucial as it acts as a bridge for data transfer. Copy this URL and proceed to your Thinkific dashboard.
3. Adding the Webhook in Thinkific
Next, we will add the copied webhook URL into Thinkific. Go back to your Thinkific account, navigate to the Webhooks section, and click on the ‘New Webhook’ button. In the Target URL field, paste the copied URL from Pabbly Connect.
For the model, select ‘User’ as you want to receive user details. Then, choose the user topic as ‘User Sign Up’ to ensure you get notified when a new user registers. Finally, click on ‘Save’ to complete the setup. This action confirms that your Thinkific account is now linked with Pabbly Connect.
4. Testing the Webhook Integration
After setting up the webhook, it’s crucial to test the integration to ensure everything is working correctly. Go back to Pabbly Connect and ensure it is waiting for a webhook response. Now, create a new user in Thinkific to trigger the webhook.
To do this, navigate to your course’s student portal and select the option to create a new account. Fill in the necessary details, such as name, email, and password, and click on ‘Sign Up.’ Once the user is created, return to Pabbly Connect to check for the captured response.
5. Successful Integration and Next Steps
Upon successful user creation, you should see the response details in Pabbly Connect. This response includes important user information such as the user’s name, email, and ID. With this integration, every time a new user registers in Thinkific, their details will be automatically sent to Pabbly Connect.
From here, you can expand your automation by sending this data to other applications, such as Google Sheets, for further processing. This flexibility allows you to manage user data efficiently without manual input.
In conclusion, setting up a webhook inside Thinkific using Pabbly Connect is a straightforward process that enhances your automation capabilities. By following these steps, you can easily capture user data and integrate it with other applications, streamlining your workflow and improving efficiency.
