Learn how to set up a webhook inside Systeme.io with Pabbly Connect. This step-by-step guide covers the integration process in detail. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Setting Up Pabbly Connect Webhook
To set up a webhook inside Systeme.io, start by accessing Pabbly Connect. This platform acts as a bridge to connect your Systeme.io account with other applications. Begin by logging into your Pabbly Connect account and navigating to the trigger section.
Once in the trigger section, search for Systeme.io as your trigger application. Select it, and then choose the trigger event labeled ‘Contact Subscribed to a Form.’ This event will activate whenever a new contact subscribes through your form in Systeme.io.
2. Copying the Webhook URL from Pabbly Connect
After selecting your trigger event, Pabbly Connect will generate a unique webhook URL. This URL is crucial as it will be used to connect your Systeme.io account with Pabbly Connect. Copy this webhook URL for the next steps.
Next, navigate to your Systeme.io dashboard. Here are the steps to follow:
- Go to the Automations section.
- Select Rules and click on the Create button.
- In the trigger event, select ‘Funnel Step Form Subscribed’.
These steps ensure that the webhook is correctly set up to capture data from your forms.
3. Creating a Rule in Systeme.io
To create a rule in Systeme.io, ensure you have selected the correct funnel and funnel step. This is essential for linking the form submission to the webhook. In the action window, you will choose the option to send a webhook.
Here’s how you can proceed with the setup:
- Select ‘Send Webhook’ as the action event.
- Paste the copied webhook URL from Pabbly Connect into the designated field.
- Save the rule to finalize the setup.
By completing these steps, you have successfully integrated Systeme.io with Pabbly Connect, allowing data to flow seamlessly when a new contact subscribes.
After setting up the webhook, it’s crucial to test the integration to ensure everything is functioning correctly. Go back to your Pabbly Connect dashboard, where you will see that it is waiting for a webhook response.
To conduct a test, fill out the lead capture form you created in Systeme.io. Here’s what you should do:
Enter the required details such as first name, last name, mobile number, and email. Submit the form.
Once you submit the form, check your Systeme.io account to confirm that a new contact has been created. Additionally, verify that the contact details appear in Pabbly Connect, indicating that the integration is successful.
In this tutorial, we explored how to set up a webhook inside Systeme.io using Pabbly Connect. This process enables seamless data transfer between applications whenever a contact subscribes to your form. By following these steps, you can effectively automate your workflows and enhance your marketing efforts.
