Learn how to set up a webhook inside Swipe Pages using Pabbly Connect. Follow our detailed tutorial for seamless integration and automation. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Setting Up Pabbly Connect for Swipe Pages Integration
To set up a webhook inside Swipe Pages, you first need to access Pabbly Connect. This platform acts as a bridge between Swipe Pages and other applications, allowing seamless data transfer. Start by logging into your Pabbly Connect account and navigating to the trigger window.
In the trigger window, search for Swipe Pages as your trigger application. Select it and choose the trigger event labeled ‘New Form Submission.’ This event will activate whenever a user submits a form created in Swipe Pages, enabling Pabbly Connect to capture the form responses effectively.
2. Configuring the Webhook URL in Swipe Pages
After selecting the trigger event in Pabbly Connect, a webhook URL will be generated. This URL is crucial as it connects your Swipe Pages account to Pabbly Connect. Copy this webhook URL to integrate it with your Swipe Pages form.
Next, log into your Swipe Pages account and navigate to the Integrations section. Click on ‘Get Started’ to create a new workflow. Name your workflow appropriately, for instance, ‘New Form Submission Workflow.’ Then, drag and drop the ‘Form Submitted’ trigger into your workflow setup.
  • Select the page associated with your form.
  • Paste the copied webhook URL into the designated field.
  • Ensure the method is set to POST.
Once you have configured these settings, proceed to save your changes. This will complete the webhook setup in Swipe Pages.
3. Testing the Integration with Pabbly Connect
After successfully configuring the webhook in Swipe Pages, it’s essential to test the integration using Pabbly Connect. You can do this by submitting a test form through your Swipe Pages form. Ensure that the form includes fields for full name, email, and phone number.
Once you submit the test form, head back to Pabbly Connect to check if the test response has been received. You should see the data from the form submission reflected in Pabbly Connect, confirming that the integration works effectively.
  • Fill in the test details accurately.
  • Click on the submit button after entering the details.
  • Check Pabbly Connect for the test response.
If the response is successfully captured, this indicates that your webhook is functioning correctly and the integration is complete.
4. Activating the Workflow in Swipe Pages
Once the testing phase is successful, it’s time to activate your workflow in Swipe Pages. Navigate back to the Integrations section and click on the ‘Active Workflow’ button. This action will ensure that your webhook is live and ready to capture new form submissions in real-time. using Pabbly Connect
With the workflow activated, any new form submission made through your Swipe Pages form will automatically trigger the webhook, sending the data to Pabbly Connect. This automation allows for instant data processing and integration with other applications as needed.
Setting up a webhook inside Swipe Pages using Pabbly Connect is a straightforward process that enhances your ability to automate data transfer. This integration allows you to capture form submissions seamlessly and utilize the data in various applications. With a few simple steps, you can ensure that your workflows are efficient and effective.
