Learn how to set up a webhook in Stripe using Pabbly Connect for seamless payment integration. Step-by-step guide with detailed instructions. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
1. Setting Up Pabbly Connect for Stripe Webhook
To begin setting up a webhook in Stripe, you will first need to access Pabbly Connect. This platform acts as a bridge to facilitate the integration between Stripe and other applications. Start by logging into your Pabbly Connect account and navigate to the trigger window.
In the trigger section, search for Stripe as your trigger application. Once selected, choose the trigger event as ‘New Charge.’ This event will activate whenever a new payment is received through Stripe. After setting this up, Pabbly Connect will generate a webhook URL that you will use in your Stripe account.
2. Configuring the Webhook in Stripe
Next, you need to configure the webhook in your Stripe account. Go to your Stripe dashboard, and ensure you are in test mode. Navigate to the Developers section and click on Webhooks. Here, you will add a new endpoint to connect with Pabbly Connect.
  • Paste the webhook URL from Pabbly Connect into the endpoint URL field.
  • Select the events you want to listen to, specifically ‘Charge Succeeded.’
  • Click on ‘Add Endpoint’ to finalize the webhook setup.
Once the endpoint is added, you will see its status as enabled, indicating that it is listening for charge succeeded events. This means that every time a payment is successful, Stripe will send the data to Pabbly Connect.
3. Testing the Webhook Integration
After setting the webhook in Stripe, it is crucial to test the integration to ensure everything is working correctly. To do this, navigate back to your Stripe account and go to the Payment Links section. Here, you will create a test payment.
Fill in the necessary details such as email, phone number, and cardholder name. Once you complete the payment process, Stripe will trigger the webhook, sending payment details to Pabbly Connect.
Return to Pabbly Connect to verify that the response has been captured. You should see the event type as ‘Charge Succeeded’ along with the payment details. This confirms that the webhook is functioning as intended and the integration is successful.
4. Handling Payment Amount with Pabbly Connect
When the payment details are received in Pabbly Connect, you may notice that the payment amount has extra zeros due to the way Stripe formats the data. To rectify this, you can use the Number Formatter feature in Pabbly Connect.
  • Select the Number Formatter action in Pabbly Connect.
  • Choose to perform a math operation to divide the amount by 100.
  • Save and test the request to confirm the correct payment amount is displayed.
By implementing this step, you ensure that the payment amount is accurately reflected in your records. This is an essential part of setting up the webhook integration effectively.
5. Saving Payment Details to Google Sheets
Finally, to store the payment details captured from Stripe, you can integrate Google Sheets with Pabbly Connect. Start by adding a new action step in your Pabbly Connect workflow.
Search for Google Sheets as your action application and select the action event to add a new row. Connect your Google Sheets account to Pabbly Connect by signing in and authorizing access. Once the connection is established, select the spreadsheet you created for storing Stripe payment details.
Map the relevant fields from the Stripe payment response to the corresponding columns in your Google Sheet. This mapping ensures that every new payment will automatically populate the Google Sheet with accurate details, including payment amount, receipt URL, and address information.
In conclusion, setting up a webhook inside Stripe using Pabbly Connect allows you to automate the process of capturing payment details effectively. By following the steps outlined, you can seamlessly integrate Stripe with other applications, ensuring accurate data management.
