Learn how to set up a webhook inside Sessions with Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect for Webhook Integration
To set up a webhook inside Sessions, we will use Pabbly Connect as our integration platform. Start by accessing your Pabbly Connect account and navigate to the trigger window.
Here, search for ‘Sessions’ as your trigger application. The trigger event you need to select is ‘Session Created.’ This event will activate whenever a new session is created, allowing Pabbly Connect to capture the session details automatically.
2. Configuring the Webhook URL in Sessions
After setting up your trigger in Pabbly Connect, you will receive a webhook URL. This URL acts as a bridge to connect your Sessions account with Pabbly Connect.
Next, go to your Sessions account and navigate to your profile settings. From there, go to ‘Workspace Settings’ and select ‘Webhooks.’ Click on ‘Add Webhook’ to input the URL from Pabbly Connect. Make sure to select the same trigger event, which is ‘Session Created,’ and set the permission to ‘Personal.’
  • Paste the Pabbly Connect webhook URL.
  • Select ‘Session Created’ as the trigger event.
  • Set permission to ‘Personal’ and confirm.
Once confirmed, you will see that the webhook has been successfully created for the ‘Session Created’ trigger event. This indicates that your Sessions account is now connected to Pabbly Connect.
3. Testing the Webhook Setup in Pabbly Connect
Now that you have configured your webhook in Sessions, it’s time to test the integration using Pabbly Connect. Return to your Pabbly Connect account, where you will notice that it is waiting for a webhook response.
To generate this response, create a new session in your Sessions account. For this example, schedule a session titled ‘Digital Marketing Workshop’ with the necessary details such as date and time. Once you schedule the session, Pabbly Connect will automatically capture the details.
  • Enter the session name: Digital Marketing Workshop.
  • Set the date and time for May 28th at 12:00 PM.
  • Schedule the session and confirm the details.
After scheduling, return to Pabbly Connect to check if the session details have been captured successfully. You should see the session ID, start and end times, and more.
4. Finalizing the Webhook Integration in Pabbly Connect
With the session details successfully captured in Pabbly Connect, your webhook integration is now complete. This means that every time a new session is created in your Sessions account, the details will be automatically sent to Pabbly Connect.
You can further enhance your automation by selecting additional actions within Pabbly Connect. This allows you to send the captured data to other applications of your choice, creating a seamless workflow.
Whenever a new session is created, Pabbly Connect will trigger and capture the incoming data in real-time, ensuring that you never miss any important details.
In this tutorial, we demonstrated how to set up a webhook inside Sessions using Pabbly Connect. By following the steps outlined, you can easily integrate Sessions with other applications, ensuring efficient data transfer and automation.
