Learn how to set up webhook inside Sendy using Pabbly Connect for seamless integration with WhatsApp and other applications. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Setting Up Pabbly Connect for Sendy Integration
To set up a webhook inside Sendy using Pabbly Connect, you first need to access your Pabbly Connect account. This platform allows seamless integration between Sendy and various applications like WhatsApp, Google Sheets, and more. Start by logging into your Pabbly Connect account.
Once logged in, navigate to the dashboard and select the option to create a new workflow. This will be the foundation for automating your tasks. You will need to choose Sendy as your trigger application, which will initiate the workflow when a new subscriber is added.
2. Configuring the Trigger Event in Sendy
In this step, you will configure the trigger event within Pabbly Connect. Select Sendy as your trigger application and choose the trigger event as ‘New Subscriber.’ This event will activate the workflow whenever a new subscriber is added to your Sendy list.
- Select Sendy as the trigger application.
- Choose ‘New Subscriber’ as the trigger event.
After copying the webhook URL, you will need to log into your Sendy account to create a new rule that utilizes this URL. This rule will allow Sendy to send subscriber data to Pabbly Connect automatically.
3. Creating a Rule in Sendy to Use Webhook
To create a rule in Sendy, go to your campaign settings and click on the ‘Rules’ option. Here, you will create a new rule that triggers when a new subscriber is added. Set the action to use the webhook you copied earlier.
Follow these steps to set up the rule:
- Click on ‘Create a New Rule’ in Sendy.
- Select ‘On Subscribe’ as the trigger.
- Paste the webhook URL into the designated field.
After setting up the rule, click on ‘Add’ to save it. This action will link Sendy to Pabbly Connect, enabling data transfer whenever a new subscriber is added.
4. Testing the Setup with a New Subscriber
Now that you have set up the rule, it’s time to test the integration. Go back to your Sendy dashboard and navigate to the list you connected. Use the subscribe form to add a new subscriber to the list. This will trigger the webhook you set up in Pabbly Connect.
Fill out the subscriber form with the necessary details and submit it. Once submitted, check your Pabbly Connect dashboard to confirm that the new subscriber data has been received successfully.
If the integration is successful, you will see the subscriber’s name, email, and other details appear in Pabbly Connect. This indicates that your webhook is functioning as intended and data is being transferred correctly.
5. Expanding Automation Options with Pabbly Connect
With the webhook successfully set up, you can now expand your automation capabilities using Pabbly Connect. You can send the subscriber data to various applications based on your needs. For instance, you can integrate with WhatsApp to send a welcome message or log the data into Google Sheets.
Consider the following applications you can connect through Pabbly Connect:
WhatsApp Cloud API for sending messages. Google Sheets for maintaining records. Slack or Discord for team notifications.
By leveraging Pabbly Connect, you can create a robust automation workflow that streamlines your email marketing efforts and enhances communication with your subscribers.
Setting up a webhook inside Sendy using Pabbly Connect allows you to automate your email marketing processes efficiently. By integrating Sendy with applications like WhatsApp and Google Sheets, you can enhance your communication and data management effortlessly.
