Learn how to set up a webhook inside SendPulse using Pabbly Connect. This step-by-step guide covers everything from creating a webhook to testing it. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Setting Up Pabbly Connect for SendPulse Webhook
To set up a webhook inside SendPulse, you first need to access Pabbly Connect. This platform acts as a bridge to connect your SendPulse account with other applications. Start by logging into your Pabbly Connect account and navigating to the trigger window.
Once in the trigger window, search for SendPulse. Select the trigger event labeled ‘New Subscriber’. This trigger will activate whenever a new subscriber is added to your SendPulse account. Make sure to read the help text provided, as it contains crucial information about the webhook URL that will connect SendPulse with Pabbly Connect.
2. Creating a Webhook in SendPulse
After setting up Pabbly Connect, the next step is to create a webhook in your SendPulse account. Go to your SendPulse profile and navigate to the account settings. From there, find the API section and click on it.
  • Click on ‘Webhooks’ under the API settings.
  • Select the ‘Create a Webhook’ button.
  • Choose the event ‘New Subscriber’ and paste the webhook URL provided by Pabbly Connect.
  • Click on ‘ADD’ to finalize the webhook creation.
By completing these steps, you have now established a connection between SendPulse and Pabbly Connect. This setup ensures that whenever a new subscriber is added in SendPulse, their details will automatically be sent to Pabbly Connect.
3. Testing the Webhook Connection
To verify that your webhook is working correctly, you need to perform a test submission. Go back to Pabbly Connect and prepare to capture a response. This involves submitting a form that you have created to add a new subscriber.
Fill in the required details in your form, such as:
Once you have filled in the form, click on the subscribe button. If successful, you will see a confirmation message indicating that the subscriber has been added. This means the subscriber details have been sent to Pabbly Connect.
4. Verifying the Subscriber Data in Pabbly Connect
After performing the test submission, check your Pabbly Connect account for the incoming data. You should see the details of the new subscriber that you just added in SendPulse. This includes the email address, full name, and phone number. using Pabbly Connect
This verification step confirms that the webhook is functioning as intended. The data captured in Pabbly Connect will be displayed in real-time, allowing you to see the new subscriber’s information immediately after it is submitted in SendPulse.
With this setup, you can now utilize the captured data for further automation processes in Pabbly Connect, enhancing your marketing efforts significantly.
In this tutorial, we explored how to set up a webhook inside SendPulse using Pabbly Connect. By following these steps, you can easily integrate your SendPulse account with other applications, ensuring seamless data transfer whenever a new subscriber is added. This process not only saves time but also enhances your marketing automation capabilities.
