Learn how to set up a webhook inside ReachInbox using Pabbly Connect for seamless integration. Follow our step-by-step tutorial to automate your email marketing processes.
1. Accessing Pabbly Connect for Webhook Setup
To set up a webhook inside ReachInbox, first, you need to access Pabbly Connect. Open a new tab in your browser and go to Pabbly.com/connect. Here, you will find options to sign in or sign up for free.
If you don’t have an account, click on the ‘Sign up for free’ button. This process takes only 2 minutes and gives you 100 free tasks every month. If you already have an account, simply click on ‘Sign in’ to access your dashboard.
Once you are signed in to Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button, which will prompt a new window for naming your workflow. You can name it according to your objective, such as ‘Setting a Webhook Inside ReachInbox’.
- This will take you to a window where you can set the trigger and action for your workflow.
In this window, you will see two boxes labeled ‘Trigger’ and ‘Action’. The trigger is the first step that gets executed in your workflow, while the action follows it. You will need to set up your trigger first.
To set up the trigger, search for the application ‘ReachInbox’ in the trigger application section of Pabbly Connect. Select it and then choose the trigger event, which is ‘Email Sent’ in this case.
Next, you will connect ReachInbox with Pabbly Connect using the provided VAB URL. This URL acts as a bridge between ReachInbox and Pabbly Connect. Make sure to follow the instructions provided to establish this connection.
- Log into your ReachInbox account and navigate to the settings tab.
- Find the integrations option and select ‘Webhooks’.
- Click on ‘Add Webhook’ and paste the VAB URL you copied from Pabbly Connect.
After you have completed these steps, you will have successfully set up the trigger in Pabbly Connect.
4. Finalizing Webhook Integration in ReachInbox
To finalize the webhook integration, return to your ReachInbox account. In the settings, under the integrations section, click on ‘Webhooks’ and then click on ‘Add Webhook’.
Paste the VAB URL you copied earlier into the designated field. You will also need to select a campaign from the dropdown menu. Choose the campaign you want to associate with this webhook, such as ‘Test Campaign’.
Select the event type as ‘Email Sent’. Finally, click on ‘Add Webhook’ to complete the integration.
Once the webhook is added, you will see a confirmation message indicating that the webhook has been successfully set up in your ReachInbox account using Pabbly Connect.
5. Testing the Webhook Integration
With the webhook now set up, it is essential to test the integration to ensure everything is working correctly. Go back to Pabbly Connect and click on the ‘Recapture Webhook Response’ button. This will allow you to see if the webhook is functioning as expected.
Send a test email through your selected campaign in ReachInbox. When the email is sent, you should see the response appear in Pabbly Connect. This response will include the details of the email sent, confirming that the integration is successful.
Check for the lead’s email address and other email details in the response. This confirms that every time you send an email, the response will be captured in Pabbly Connect.
By following these steps, you have successfully set up a webhook inside ReachInbox using Pabbly Connect, allowing for seamless integration and automation of your email marketing processes.
In this tutorial, we explored how to set up a webhook inside ReachInbox using Pabbly Connect. By following the specific steps outlined, you can automate email tracking and integrate with other applications effectively. This setup enhances your email marketing efforts significantly.
