Learn how to set up a webhook inside Paperform using Pabbly Connect to automate your data transfer seamlessly. Follow our step-by-step guide for easy integration.
1. Setting Up Pabbly Connect for Paperform Webhook
To set up a webhook inside Paperform using Pabbly Connect, start by accessing your Pabbly Connect account. This integration allows you to automate data transfer whenever a new form submission occurs in Paperform.
In Pabbly Connect, search for Paperform as your trigger application. Select it and choose the trigger event as ‘New Form Submission.’ This will initiate the workflow whenever a form is submitted.
2. Configuring Webhook in Paperform
Next, you need to configure the webhook in your Paperform account. To do this, navigate to the form you created in Paperform. In the edit mode, go to the ‘After Submission’ settings and then click on ‘Integrations’ followed by ‘Webhooks.’ Here, you will add the webhook URL provided by Pabbly Connect.
  • Copy the webhook URL from Pabbly Connect.
  • Paste it into the new webhook field in Paperform.
  • Click on ‘Create’ to finalize the integration.
Once you have successfully added the webhook, ensure that the connection is saved. This will allow the data from new form submissions to be sent to Pabbly Connect automatically.
3. Testing the Webhook Integration
After configuring the webhook, it’s crucial to test the integration to ensure it works as expected. Open the link to your Paperform and fill out the form with sample data. Once you submit the form, the data should be sent to Pabbly Connect.
In Pabbly Connect, you will see that it is waiting for a webhook response. Once the form is submitted, check the response in your Pabbly Connect dashboard. You should see the details of the submission, including the submission ID, email, and any other fields you included in your form.
4. Automating Data Transfer to Other Applications
With the webhook successfully set up and tested, you can now automate data transfer to other applications using Pabbly Connect. After capturing the form submission, click on the action step in Pabbly Connect to select the application you want to send the data to.
This could be any application supported by Pabbly Connect. The setup allows for real-time data transfer, ensuring that every new form submission triggers the desired actions in your connected applications.
Setting up a webhook inside Paperform using Pabbly Connect is a straightforward process that enhances your workflow automation. By following the steps outlined, you can ensure seamless data transfer from Paperform to your desired applications, enabling efficient operations.
