Learn how to set up a webhook inside NativeForms using Pabbly Connect for seamless data integration. Follow our step-by-step tutorial now! Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Understanding Pabbly Connect and Its Role
Pabbly Connect is essential for setting up a webhook inside NativeForms. It acts as a bridge to automate data transfer between NativeForms and other applications. By using Pabbly Connect, you can efficiently manage form submissions and integrate them with various platforms like Google Sheets and Slack. using Pabbly Connect
NativeForms allows users to create and manage forms for capturing responses, feedback, and leads. By connecting NativeForms with Pabbly Connect, you can easily transfer data automatically whenever a form is submitted, enhancing your workflow and saving time.
2. Setting Up Webhook in NativeForms Using Pabbly Connect
To set up the webhook in NativeForms, start by accessing your Pabbly Connect account. Select NativeForms as the trigger application. This will begin the process of integrating it with Pabbly Connect. using Pabbly Connect
  • Log in to your Pabbly Connect account.
  • Select NativeForms as the trigger application.
  • Choose the trigger event, which is ‘Form Completed’.
Once you select the trigger event, Pabbly Connect will provide you with a webhook URL. This URL is crucial as it allows NativeForms to send data to Pabbly Connect upon form submission. Copy this URL to proceed.
3. Configuring the Webhook in NativeForms
After copying the webhook URL, log in to your NativeForms account. Select the form you want to connect, and navigate to the ‘Edit Form’ section. Here, you need to configure the webhook settings to link it with Pabbly Connect. using Pabbly Connect
Scroll down to find the ‘Webhook Configuration’ option. Click on ‘New Webhook’ and paste the copied URL into the provided field. You will also need to select the event type that triggers the webhook, which should be set to ‘Form Completed’.
  • Paste the webhook URL from Pabbly Connect.
  • Select ‘Form Completed’ as the event type.
  • Click ‘Create Webhook’ to save the settings.
Once you create the webhook, Pabbly Connect will indicate that it is waiting for a response from NativeForms. This means you are now ready to test the integration.
To test the integration, go back to the form you configured in NativeForms. Fill out the form with dummy data and submit it. This action will trigger the webhook, sending the form data to Pabbly Connect. using Pabbly Connect
After submitting the form, return to Pabbly Connect to check if the response has been received. You should see the details of the form submission displayed in the Pabbly Connect interface, confirming that the integration works correctly.
Once you verify that the data has been captured, you can proceed to set up action steps in Pabbly Connect to send this data to other applications like Google Sheets or Slack.
5. Conclusion
In conclusion, setting up a webhook inside NativeForms using Pabbly Connect is a straightforward process that enhances your data management capabilities. By following these steps, you can automate the transfer of form submissions to various applications, streamlining your workflow.
Pabbly Connect serves as the central platform that facilitates this integration, allowing users to connect NativeForms with tools like Google Sheets and Slack effortlessly. Start using Pabbly Connect today to optimize your form management!
