Learn how to integrate Mend and Set up Webhook inside Moosend using Pabbly Connect with this step-by-step tutorial. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Setting Up Webhook in Pabbly Connect
To set up a webhook inside Moosend, first, you need to access Pabbly Connect. This powerful integration platform allows you to connect various applications seamlessly. Start by logging into your Pabbly Connect account and navigate to the trigger setup.
In the trigger window, search for ‘Mend’ as your trigger application. Select the trigger event as ‘New Subscriber.’ This event will activate whenever a new subscriber is added to your mailing list, allowing you to capture their details efficiently.
2. Copying the Webhook URL from Pabbly Connect
Once you select the trigger event, a webhook URL will be generated in Pabbly Connect. This URL is crucial as it acts as a bridge between your Mend account and Pabbly Connect. Make sure to copy this webhook URL carefully for the next steps.
Now, navigate to your Mend account. You will find the option for Automation. Here’s how to proceed:
  • Go to Automation and select ‘Create New Automation’.
  • Choose the same trigger event as in Pabbly Connect, which is ‘When someone subscribes to a list’.
  • Set the trigger to activate only once for the first subscription.
After configuring the trigger, click on ‘Save’ to ensure your settings are stored properly.
3. Adding Action to Post Webhook in Mend
Next, you need to add an action to your Mend automation. Click on the ‘Add’ button and select the action to ‘Post a Webhook.’ Here, you will paste the webhook URL you copied from Pabbly Connect. This step is critical as it establishes the link between Mend and Pabbly Connect.
After pasting the URL, click on ‘Save’ to finalize the action. You will see a confirmation that your automation has been updated successfully. Now, save this automation as a recipe, giving it an appropriate name like ‘New Automation’ and fill in the relevant details like description and industry type.
4. Activating the Automation in Mend
After saving your automation recipe, the next step is to activate it. Click on the activation button to make your automation live. This means that your connection between Pabbly Connect and Mend is now functional. Whenever a new subscriber is added, their details will be sent to Pabbly Connect automatically.
To verify that everything is set up correctly, return to Pabbly Connect. You should see a test response indicating that the webhook is waiting for a response. This confirms that the connection is established and ready to capture new subscriber data.
5. Testing the Integration
To test the integration, create a new subscriber in your Mend account by filling out the required form fields such as name, email, and phone number. After submitting the form, you should receive a success message indicating that the subscriber has been added to your list.
Now, return to Pabbly Connect where you should see that the subscriber’s details have been captured successfully. This includes user ID, email address, and other relevant information. This verification step ensures that your webhook setup is functioning correctly and that data flows seamlessly from Mend to Pabbly Connect.
Setting up a webhook inside Moosend using Pabbly Connect enables you to automate the process of capturing new subscribers efficiently. This integration allows for seamless data transfer, enhancing your email marketing strategy.
