Learn how to set up a webhook inside Modwebs using Pabbly Connect to automate data transfer to Google Sheets. Follow our step-by-step tutorial for seamless integration.
1. Introduction to Pabbly Connect and Modwebs
In this tutorial, we will explore how to set up a webhook inside Modwebs using Pabbly Connect. This integration allows you to automate data transfer from Modwebs to Google Sheets seamlessly. Modwebs is a platform designed for creating customizable websites, making it ideal for businesses looking to establish an online presence quickly.
Using Pabbly Connect, you can easily connect your Modwebs account with Google Sheets. This setup will enable you to store all lead details in one place whenever a new form submission occurs on your Modwebs website. Let’s dive into the steps for setting up this integration.
The first step in our integration process is to set up the trigger in Pabbly Connect. Start by logging into your Pabbly Connect account and selecting Modwebs as your trigger application. You will then be prompted to choose the trigger event.
Select ‘New Form Submission’ as your trigger event. This will allow Pabbly Connect to capture data when a new form is submitted on your Modwebs website. After selecting the trigger event, you will receive a webhook URL that is essential for connecting Modwebs with Pabbly Connect.
- Log into Pabbly Connect and select Modwebs as the trigger application.
- Copy the provided webhook URL for use in Modwebs.
Now that you have your webhook URL, you can proceed to set it up in your Modwebs account. This step is crucial for enabling the data transfer process.
3. Configuring Modwebs to Connect with Pabbly Connect
To configure Modwebs, log into your Modwebs account and navigate to the Dashboard. Click on the ‘My Sites and Funnel’ option, and select your website. From there, go to the settings option and choose ‘Show Settings’.
Under the settings menu, locate the ‘Applications’ section on the left sidebar. Click on the ‘Add Application’ button and select the ‘Connect Webhook’ option. Here, you will need to paste the webhook URL you copied earlier from Pabbly Connect.
- Navigate to your Modwebs Dashboard and select your website.
- Access the settings and find the ‘Applications’ section.
- Add the ‘Connect Webhook’ application and paste the webhook URL.
After entering the URL, select the same event you chose in Pabbly Connect (‘New Form Submission’) and click ‘Save’. This action successfully connects your Modwebs account with Pabbly Connect.
4. Testing the Webhook Connection
Once you have set up the webhook in Modwebs, it is important to test the connection to ensure everything is working correctly. Return to your Pabbly Connect dashboard, where you will see that it is waiting for a webhook response.
To generate a test response, go to your Modwebs website and fill out the lead form. Enter dummy data, such as a name, email, phone number, and project type. Click on the ‘Get in Touch’ button to submit the form. This action will trigger the webhook.
Go back to your Modwebs website and fill out the lead form with test data. Submit the form to trigger the webhook. Check Pabbly Connect for the captured response.
After submitting the form, check your Pabbly Connect dashboard. You should see the response containing all the details you submitted, confirming that the integration is successful.
5. Conclusion and Next Steps
In this tutorial, we have successfully set up a webhook inside Modwebs using Pabbly Connect. By following the steps outlined, you can automate the process of capturing form submissions and transferring that data to Google Sheets or other applications.
With Pabbly Connect, you can further enhance your workflow by connecting additional applications. This integration not only saves time but also ensures that your data is organized effectively. Start exploring more integrations and make the most out of your Modwebs and Pabbly Connect experience!
