Learn how to set up a webhook inside Linear using Pabbly Connect for seamless integration with Google Chat and The Happening. Follow our step-by-step guide.
1. Introduction to Pabbly Connect and Linear
In this section, we will explore how to set up a webhook inside Linear using Pabbly Connect. Linear is a platform designed for product teams to manage their products and track issues efficiently. By integrating Linear with Pabbly Connect, you can automate repetitive tasks and streamline your workflow.
Pabbly Connect acts as the central integration platform that allows you to connect Linear with various applications like Google Chat and The Happening. This integration helps in capturing responses automatically whenever a specific event occurs in Linear, enhancing productivity and team collaboration.
2. Setting Up the Webhook in Linear
To set up the webhook in Linear, we first need to access Pabbly Connect. Start by selecting Linear as your trigger application. This step is crucial as it defines when the automation will be triggered. In this case, we will choose the event type as ‘New Issue’ to capture any new issues created in Linear. using Pabbly Connect
  • Select Linear as the trigger application.
  • Choose the trigger event as ‘New Issue’.
Once you have copied the webhook URL, proceed to your Linear account. Navigate to the profile section, select ‘Workspace Settings’, and then go to the ‘API’ section. Here, you will create a new webhook by pasting the URL you copied from Pabbly Connect.
3. Configuring Linear Settings for Webhook
In this segment, we will configure the settings in Linear to finalize the webhook setup. After pasting the webhook URL into Linear, you must label your webhook appropriately. For example, you can name it ‘New Issues’. This label helps you identify the webhook’s purpose easily. using Pabbly Connect
  • Label your webhook as ‘New Issues’.
  • Select the data change event for capturing new issues.
  • Click on ‘Create Webhook’ to finalize your setup.
After creating the webhook, return to Pabbly Connect. You will notice that it is now waiting for a response from Linear. This indicates that your webhook is successfully set up and ready to capture data whenever a new issue is created.
4. Testing the Webhook Connection
Now that we have set up the webhook, it’s time to test the connection. To do this, create a new issue in Linear. This action should trigger the webhook and send the relevant data to Pabbly Connect. using Pabbly Connect
Enter the title and description of the issue, for example, ‘App Crashes on Login’. Make sure to fill in all necessary details, such as the issue type and priority. Once the issue is created, head back to Pabbly Connect to see if the response is captured.
If everything is set up correctly, you will see the details of the new issue displayed in Pabbly Connect, confirming that the webhook is functioning as intended. This step is crucial for ensuring that your automation works seamlessly.
5. Integrating with Google Chat Using Pabbly Connect
With the webhook successfully set up, we can now integrate Google Chat to send notifications whenever a new issue arises in Linear. In Pabbly Connect, select Google Chat as your action application. using Pabbly Connect
Configure the action step to send a message to your team in Google Chat. This message will contain the details of the new issue created in Linear. By setting up this action, you ensure that your team is promptly informed about any new issues, enhancing communication and response times.
Once you have configured the action step, test the entire workflow by creating another new issue in Linear. Check Google Chat to confirm that the message has been sent successfully. This integration significantly improves your team’s efficiency by automating notifications through Pabbly Connect.
In this tutorial, we demonstrated how to set up a webhook inside Linear using Pabbly Connect. By following the steps outlined, you can seamlessly integrate Google Chat and automate notifications for new issues. This integration not only saves time but also enhances team collaboration and efficiency.
