Learn how to set up a webhook inside Landingi using Pabbly Connect to automate data transfer effectively. Follow our step-by-step guide for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Setting Up Pabbly Connect for Webhook Integration
To set up a webhook inside Landingi, the first step involves accessing Pabbly Connect. This platform acts as the central hub for integrating applications and transferring data efficiently.
Begin by logging into your Pabbly Connect account. From the dashboard, navigate to the ‘Trigger’ window. Here, search for the Landingi application and select it as your trigger application. The trigger event will be set to ‘New Lead from Landing Page,’ which initiates the process whenever a new lead is created.
2. Copying the Webhook URL from Pabbly Connect
After selecting the trigger, Pabbly Connect provides a unique webhook URL. This URL is critical as it connects your Landingi account with Pabbly Connect.
Make sure to read the help desk instructions provided by Pabbly Connect carefully. To copy the webhook URL, click on the URL displayed in the trigger setup. This URL will be used in the Landingi platform to complete the integration.
3. Configuring the Webhook in Landingi
Now, navigate to your Landingi account. Go to the dashboard and select the page you wish to edit. Click on the ‘Edit’ button to enter the settings of the page. In the settings menu, locate the ‘Integrations’ section and scroll down to find the ‘Webhook’ option. using Pabbly Connect
- Remove any existing webhook URL if necessary.
- Paste the copied webhook URL from Pabbly Connect into the designated field.
- Set the request method to POST.
- Specify the details you want to send, such as name, email, and phone number.
After entering the webhook URL and settings, click on ‘Save’ and then ‘Save and Close’ to activate the integration. Ensure to publish the changes in Landingi for the integration to take effect.
4. Testing the Webhook Integration
With the webhook set up in Landingi, it’s time to test the integration through Pabbly Connect. Go back to your Pabbly Connect dashboard where you will see a message indicating that it is waiting for a webhook response.
Perform a test submission on your Landingi page. Fill in the required fields with test data, such as a demo name, email, and phone number, then submit the form. After submission, you should receive a confirmation message on the page, indicating the lead was created successfully.
5. Verifying Data Reception in Pabbly Connect
After the test submission, return to Pabbly Connect to verify that the data has been received. You should see the details of the lead submission displayed in the response section. This confirms that the integration is working correctly.
Now, every time a new lead is created in Landingi, the details will be automatically captured in Pabbly Connect. This seamless integration allows for real-time data transfer and workflow execution, enabling you to send lead details to other applications as needed.
Setting up a webhook inside Landingi using Pabbly Connect streamlines your lead management process. With this integration, you can automatically capture and transfer lead details, enhancing your workflow efficiency.
