Learn how to set up a webhook inside Kommo using Pabbly Connect for seamless integration with Google and other applications. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Setting Up Pabbly Connect for Webhook Integration
To set up a webhook inside Kommo, you need to start with Pabbly Connect. This platform allows you to automate workflows and integrate different applications seamlessly. First, log in to your Pabbly Connect account and navigate to the dashboard.
Once you are on the dashboard, click on the ‘Create Workflow’ button. This initiates the process of setting up your integration. You will be prompted to choose a trigger application, which in this case will be Kommo.
2. Selecting Kommo as the Trigger Application
After creating a workflow, you will need to select Kommo as your trigger application in Pabbly Connect. This allows Pabbly Connect to listen for specific events that occur in Kommo.
  • Search for ‘Kommo’ in the applications list.
  • Select ‘New Lead’ as the trigger event.
  • Click on the ‘Connect’ button to link your Kommo account.
Once you have set Kommo as your trigger application, you will receive a webhook URL from Pabbly Connect. This URL is essential for linking your Kommo account to the automation process.
3. Configuring the Webhook in Kommo
Next, you need to configure the webhook settings inside your Kommo account. Go to the settings section and find the integrations option. Here, you will set up the webhook using the URL provided by Pabbly Connect.
  • Click on ‘Integrations’ from the left sidebar.
  • Select ‘Webhooks’ from the integrations menu.
  • Click on ‘Add Webhook’ and paste the webhook URL from Pabbly Connect.
After entering the webhook URL, select the event type as ‘Incoming Lead Added’. This ensures that every time a new lead is generated in Kommo, the data will be sent to Pabbly Connect.
4. Testing the Connection Between Kommo and Pabbly Connect
With the webhook configured, it’s time to test the connection. Go back to Pabbly Connect and initiate a test submission. This will help you confirm that the webhook is functioning correctly.
To do this, create a test lead in Kommo by filling out the lead form. After submitting the form, return to Pabbly Connect to check if the data has been received successfully. You should see the details of the test lead captured in Pabbly Connect.
5. Finalizing Your Webhook Setup
Once you have confirmed that Pabbly Connect is receiving data from Kommo, you can finalize your webhook setup. This means that every new lead created in Kommo will automatically trigger actions in other applications connected via Pabbly Connect.
To complete the setup, click on the ‘Save’ button in Pabbly Connect. This ensures that your workflow is active and ready to process incoming leads from Kommo to your other applications seamlessly.
In this tutorial, we explored how to set up a webhook inside Kommo using Pabbly Connect. By following these steps, you can automate the transfer of lead data to various applications, enhancing your workflow efficiency.
