Learn how to set up a webhook inside JetFormBuilder using Pabbly Connect. This step-by-step tutorial covers all the necessary integrations and configurations. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Setting Up Pabbly Connect for JetFormBuilder
To set up a webhook inside JetFormBuilder, you first need to access Pabbly Connect. This platform enables seamless integration between various applications, including JetFormBuilder. Start by logging into your Pabbly Connect account and creating a new workflow.
Once your workflow is created, you will see two main sections: Trigger and Action. The Trigger section is where you will select JetFormBuilder as your application and set the event to ‘New Submission.’ This step is crucial as it determines when the webhook will be activated.
2. Creating the Trigger in JetFormBuilder
After selecting JetFormBuilder as the trigger application in Pabbly Connect, you need to choose the trigger event. In this case, select ‘New Submission.’ This means that every time a new form submission is made, Pabbly Connect will capture the data.
  • Select JetFormBuilder as the trigger application.
  • Choose ‘New Submission’ as the trigger event.
After copying the webhook URL, you will need to connect it back to JetFormBuilder. This URL acts as a bridge between the two platforms, ensuring that every new submission is sent to Pabbly Connect for processing.
3. Configuring JetFormBuilder Settings
Next, navigate to your JetFormBuilder form settings. Click on the settings button located in the top right corner of the form editor. In the settings menu, find the ‘Post Submit Actions’ option.
Click on ‘Add New Action’ and select the ‘Call Webhook’ option from the dropdown menu. This is where you will paste the webhook URL you copied earlier from Pabbly Connect. After pasting the URL, make sure to click on the ‘Update’ button to save your changes.
4. Testing the Webhook Integration
To ensure that the webhook integration is successful, you need to perform a test submission using the form you created in JetFormBuilder. Fill in the required details such as name, email, and mobile number, and then click on the submit button. using Pabbly Connect
Once the form is submitted, return to your Pabbly Connect workflow and check for a webhook response. You should see the details of your test submission captured by Pabbly Connect, confirming that the integration works correctly.
5. Setting Up Action Steps in Pabbly Connect
Now that the webhook is successfully set up, you can configure action steps in Pabbly Connect. This allows you to automate further processes, such as sending notifications to Slack, Discord, or creating records in Google Sheets.
Decide on the action you want to take after a form submission. You can choose to send data to various platforms or create a record based on the form submission details. This is where Pabbly Connect’s versatility shines, enabling you to customize the workflow according to your needs.
In conclusion, using Pabbly Connect to set up a webhook inside JetFormBuilder allows for efficient data handling and integration with multiple applications. By following these steps, you can streamline your workflows and enhance your business processes effectively.
