Learn how to set up a webhook inside Instamojo using Pabbly Connect. Follow this step-by-step guide to automate your payment processes seamlessly. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To set up a webhook inside Instamojo, first, you need to access Pabbly Connect. This integration platform allows you to connect various applications easily. Visit the Pabbly Connect homepage and either sign in if you are an existing user or click on ‘Sign Up for Free’ to create a new account.
Once you create your account, you will receive 100 free tasks every month, which you can use to explore Pabbly Connect. After signing in, you will be directed to the dashboard where you can manage your workflows and set up new integrations.
After accessing the dashboard of Pabbly Connect, you will need to create a new workflow. Click on the ‘Create Workflow’ button. You will be prompted to name your workflow; for this integration, name it ‘How to Set Up Webhook Inside Instamojo’.
  • Enter the name for your workflow.
  • Select the folder to save your workflow.
  • Click on ‘Create’ to finalize your workflow setup.
After creating the workflow, you will see two windows: one for the trigger and one for the action. In this case, the trigger will be set to Instamojo, and the action will be set to Google Sheets. This configuration will automate the process of recording sales in Google Sheets whenever a new sale occurs in Instamojo.
3. Setting Up the Trigger with Instamojo
In the trigger section of Pabbly Connect, select Instamojo as your trigger application. The trigger event you need to choose is ‘New Sale’. This event will initiate the workflow whenever a sale is made in Instamojo.
Once you select the trigger event, Pabbly Connect will provide you with a unique webhook URL. Copy this URL, as it will be used to connect your Instamojo account. Follow these steps to configure your Instamojo account:
  • Log into your Instamojo account.
  • Select the product you want to connect (e.g., Java ebook).
  • Navigate to the advanced settings and paste the webhook URL.
After pasting the webhook URL, click on ‘Save’. This will successfully link your product with Pabbly Connect, allowing it to capture data from Instamojo whenever a sale occurs.
4. Testing the Webhook Connection
After setting up the webhook, it’s crucial to test the connection. Go back to Pabbly Connect and you will see a message indicating that it is waiting for a webhook response. To initiate this, make a test purchase of the product you have connected.
Fill in the required details such as the customer’s name, email, and phone number, and proceed to make the payment. Once the payment is successful, Pabbly Connect will capture the response automatically. You should see all transaction details displayed in the Pabbly dashboard.
Check for the payment status (should be ‘Credit’). Confirm that all details like payment ID and customer information are captured.
This test confirms that your webhook setup is functioning correctly. You can now proceed to the next steps of integrating with Google Sheets.
5. Integrating Google Sheets with Pabbly Connect
To record the transaction details in Google Sheets, set Google Sheets as your action application in Pabbly Connect. Select the action event as ‘Add New Row’. This will allow you to create a new entry in your spreadsheet for every sale made.
Connect your Google Sheets account and select the specific spreadsheet where you want to record the transaction details. Map the fields from Instamojo to the corresponding columns in your Google Sheets, such as payment status, customer name, email, phone number, and amount.
Select your spreadsheet from the dropdown menu. Map the relevant fields for each transaction detail.
After mapping the fields, click on ‘Save and Send Test Request’. Check your Google Sheets to ensure that a new row has been added with all the transaction details. This confirms that your integration between Instamojo and Google Sheets via Pabbly Connect is working perfectly.
In this tutorial, we demonstrated how to set up a webhook inside Instamojo using Pabbly Connect. By following the steps outlined, you can automate the process of recording payment transactions in Google Sheets seamlessly. This integration enhances efficiency and ensures that you have real-time access to your sales data.
