Learn how to set up a webhook inside Graphy using Pabbly Connect to automate your online course transactions seamlessly. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Setting Up Pabbly Connect for Graphy Webhook
To set up a webhook inside Graphy, you first need to access Pabbly Connect. This platform acts as a bridge between Graphy and other applications, allowing data transfer during specific events. Start by logging into your Pabbly Connect account and navigate to the ‘Trigger’ window.
In the Trigger window, search for Graphy as your trigger application. You will select the trigger event as ‘Success Transaction’. This event will initiate the process whenever a transaction is successfully completed in Graphy, thus enabling seamless integration with Pabbly Connect.
2. Copying the Webhook URL from Pabbly Connect
After selecting the trigger event, you will notice a Webhook URL provided by Pabbly Connect. This URL is crucial as it connects your Graphy account with Pabbly Connect. Make sure to read any help documentation provided, as it will guide you through the integration process.
Next, you need to configure this Webhook URL in your Graphy account. Navigate to the Integrations section in Graphy, then select Webhooks. Here, you will add a new webhook by pasting the copied URL from Pabbly Connect. Remember to remove any unnecessary parts from the URL, ensuring it starts with ‘https’.
3. Configuring the Webhook in Graphy
Once the Webhook URL is pasted into Graphy, you need to provide a description. For example, you might label it as ‘Successful Payment’ to identify the purpose of this webhook easily. Next, you will select the event type as ‘Success Transaction’ so that it listens for successful payment events.
After filling in these details, click on the ‘Save’ button. This action confirms that you have successfully added the webhook to your Graphy account. The integration with Pabbly Connect is now established, and you will see a confirmation message indicating that the webhook has been successfully set up.
4. Testing the Integration with a Sample Payment
To ensure that the webhook is functioning properly, you need to test it by making a sample purchase in Graphy. Go to the courses you have created and select a course to purchase. For example, you might choose ‘Core PHP Programming’.
Proceed through the checkout process by filling in the required information. When prompted for payment details, use dummy card information, as you are likely in a testing environment. After completing the payment, you should see a confirmation that your order was successful.
  • Select the course to purchase.
  • Fill in the dummy payment details.
  • Complete the purchase and confirm the transaction.
Once the payment is successful, return to Pabbly Connect to check if the transaction details have been captured. You should see the order ID, course name, and other relevant details displayed, confirming that the webhook integration is working as intended.
5. Conclusion: Successful Webhook Setup in Graphy
In conclusion, by following these steps, you have successfully set up a webhook inside Graphy using Pabbly Connect. This integration allows you to automate the process of capturing payment details whenever a transaction occurs. You can now easily send this data to other applications for further processing.
Utilizing Pabbly Connect not only simplifies your workflow but also enhances your ability to manage online course transactions effectively. With this setup, you can focus on creating and selling your courses while the integration handles the backend processes seamlessly.
