Learn how to set up a webhook inside GoZen Forms using Pabbly Connect for seamless data integration. Step-by-step guide included. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Setting Up Pabbly Connect for GoZen Forms
To set up a webhook inside GoZen Forms, you need to use Pabbly Connect. Start by logging into your Pabbly Connect account and navigating to the trigger window. Here, search for GoZen Forms as your trigger application.
The trigger event you will select is ‘On Form Submission’. This means that every time a form is submitted, the webhook will activate. A unique webhook URL will be generated, which is essential for connecting your GoZen Forms with Pabbly Connect.
2. Configuring GoZen Forms with Pabbly Connect
Next, go to your GoZen Forms account. Here, navigate to your dashboard and select the specific form you wish to integrate. For this tutorial, we will use a form named ‘Lead Forms’.
  • Log into your GoZen Forms account.
  • Select the ‘Workspace’ and choose the form.
  • Go to ‘Integrate’ and scroll down to ‘Custom Webhook’.
Once you find the custom webhook option, click on connect. In the webhook URL field, copy the URL generated by Pabbly Connect and paste it into the GoZen Forms integration section. Click on ‘Create’ to finalize the connection.
3. Testing the Webhook Setup
After setting up the webhook, it’s time to test the integration. Go back to Pabbly Connect and check that it is waiting for a webhook response. This indicates that the setup is ready to capture data from form submissions.
To perform a test submission, open the form link in an incognito window. Fill out the form with dummy data, such as a name, email, and phone number. Submit the form to trigger the webhook.
4. Verifying Data Receipt in Pabbly Connect
Once you submit the form, return to your Pabbly Connect account. You should see that a response has been received, confirming that the data has been captured successfully. This response will include all the details you filled out in the form.
Additionally, you can verify the submission in your GoZen Forms account under the responses section. You will see the submitted data along with the date and time of submission, ensuring that the integration works correctly.
5. Conclusion: Successful Webhook Setup with Pabbly Connect
In this tutorial, we successfully set up a webhook inside GoZen Forms using Pabbly Connect. This integration allows you to capture form submissions in real-time and send the data to other applications as needed. You can create powerful automations and streamline your workflows using this method.
By following the steps outlined above, you can easily connect your forms with various applications, enhancing your data collection process. Utilize Pabbly Connect to explore further integrations and automate your tasks efficiently.
