Learn how to set up a webhook inside GoZen Forms using Pabbly Connect to streamline data collection. Follow our step-by-step guide for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Setting Up Webhook Inside GoZen Forms with Pabbly Connect
To set up a webhook inside GoZen Forms, you first need to access Pabbly Connect. This platform allows you to create automated workflows between applications. Start by logging into your Pabbly Connect account and navigating to the trigger window.
In the trigger window, search for ‘GoZen Forms’ as your trigger application. The trigger event you need to select is ‘On Form Submission’. This event will initiate the workflow whenever a form is submitted in GoZen Forms.
2. Copying Webhook URL from Pabbly Connect
Once you have selected the trigger event, you will see a webhook URL provided by Pabbly Connect. This URL acts as a bridge between your GoZen Forms account and Pabbly Connect. Make sure to read any instructions provided carefully, as they guide you on how to use this URL.
Next, log into your GoZen Forms account. Navigate to your workspace and select the specific form you want to connect. Click on the ‘Integrate’ option and scroll down to find ‘Custom Webhook’. Here, you will paste the webhook URL you copied from Pabbly Connect.
- Log into GoZen Forms account.
- Select the desired form.
- Navigate to Integrate > Custom Webhook.
- Paste the webhook URL and click Create.
After pasting the URL, click on the ‘Create’ button to finalize the connection. This successfully sets up the webhook inside your GoZen Forms account, allowing you to capture form submissions in real-time.
3. Testing the Integration with Pabbly Connect
Now that the webhook is set up, it’s time to test the integration. Return to your Pabbly Connect dashboard, where you will see that it is waiting for a webhook response. This indicates that the connection is ready to receive data.
To test, open the form you just integrated in an incognito window. Fill out the form with test data, such as a name, email, and phone number, and submit it. After submitting, you should see a confirmation message indicating the form was successfully submitted.
- Open the form in incognito mode.
- Enter test data (name, email, phone).
- Submit the form.
Once the form is submitted, return to Pabbly Connect to view the captured response. You should see the details of the submission, confirming that the integration is working correctly.
4. Viewing Responses in GoZen Forms and Pabbly Connect
After successfully testing the webhook, you can view the responses in both GoZen Forms and Pabbly Connect. In your GoZen Forms account, navigate to the responses section to see the submitted data, including the name, email, and phone number.
In Pabbly Connect, the response will also be available, showing all the details filled during the form submission. This allows you to confirm that the data has been successfully captured and is ready for further processing.
With this setup, every time a new form submission occurs, the data will be automatically sent to Pabbly Connect, enabling you to create workflows with other applications as needed. This seamless integration enhances your data collection process.
In conclusion, setting up a webhook inside GoZen Forms using Pabbly Connect is a straightforward process. By following the steps outlined in this tutorial, you can easily integrate GoZen Forms with various applications, streamlining your data collection and automation efforts.
