Learn how to set up a webhook inside FunnelKit using Pabbly Connect to automate user data integration with Google Sheets and more. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
1. Setting Up Webhook with Pabbly Connect
To set up a webhook inside FunnelKit, you will first need to access Pabbly Connect. This integration platform allows you to connect your applications seamlessly. Start by logging into your Pabbly Connect account and navigating to the trigger section.
In the trigger window, search for the FunnelKit application. Select it, and choose the trigger event as ‘New User’. This event will activate whenever a new user is created in FunnelKit, allowing data to flow to the connected applications via Pabbly Connect.
2. Creating Automation in FunnelKit
After setting up your trigger in Pabbly Connect, go to your WordPress dashboard where FunnelKit is installed. Navigate to the FunnelKit automations section and click on ‘Add New Automation’. Give your automation a name, such as ‘Pabbly Connect Automation’, and click ‘Create’.
- Select the trigger application as WordPress.
- Choose the trigger event as ‘User Created’.
- Click ‘Done’ to finalize your trigger selection.
Now, add an action step by clicking on the plus sign. Choose to send data to Pabbly Connect and click ‘Done’. You will need to paste the webhook URL from Pabbly Connect into the designated field.
3. Mapping Data to Send to Pabbly Connect
Next, you’ll need to specify the data you want to send to Pabbly Connect. In the data fields, you can include crucial user information such as email, first name, last name, and username. Use the merge tags feature to insert the corresponding values from the user data.
- Add the user’s email by selecting it from the merge tags.
- Repeat this for first name, last name, and username.
- Click ‘Save’ once all fields are populated.
After saving, your automation in FunnelKit will now be connected to Pabbly Connect, ready to capture any new user data sent through the webhook.
4. Testing the Webhook Automation
To ensure that your webhook setup is functioning correctly, perform a test submission. Fill out the form with new user details, such as username, email, first name, and last name, then click ‘Submit’. This action will trigger the webhook in Pabbly Connect.
Once the user is successfully registered, return to Pabbly Connect to check if the details have been captured. You should see the new user information reflected in the webhook response section, confirming that the integration is working as intended.
5. Adding User Data to Google Sheets
After confirming that the webhook is functioning, you can extend the automation to include Google Sheets. In Pabbly Connect, search for Google Sheets as your action application. Choose the action event as ‘Add New Row’ to store the new user details.
Connect your Google account to Pabbly Connect by allowing access. Select the spreadsheet you created for FunnelKit new users and ensure that the correct sheet is detected. Use the mapping feature again to link the fields from the webhook response to the appropriate columns in your Google Sheet.
In conclusion, using Pabbly Connect to set up a webhook inside FunnelKit allows for seamless integration of user data into Google Sheets and other applications. This automation not only saves time but also ensures that user data is captured accurately and efficiently.
