Learn how to set up a webhook inside FunnelKit using Pabbly Connect. Follow this detailed step-by-step tutorial to integrate your applications seamlessly. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Setting Up Pabbly Connect for FunnelKit Integration
To set up a webhook inside FunnelKit, you first need to access Pabbly Connect. This platform acts as the central hub for integrating various applications like FunnelKit, Google Sheets, and more. Start by logging into your Pabbly Connect account.
Once logged in, navigate to the trigger window. Here, you will search for the FunnelKit application and select it. The trigger event you will choose is ‘New User’. This event will initiate the webhook whenever a new user is created in FunnelKit.
2. Copying the Webhook URL from Pabbly Connect
After selecting the trigger event, Pabbly Connect will generate a webhook URL. This URL is crucial as it will serve as the bridge connecting your FunnelKit account with Pabbly Connect.
- Locate the webhook URL in Pabbly Connect.
- Copy the URL to your clipboard for later use.
This URL will be used in the FunnelKit automation settings. Ensure you read any help documentation provided for additional context on using the webhook URL correctly.
3. Configuring FunnelKit with the Webhook URL
Now, switch to your WordPress dashboard where FunnelKit is installed. Go to FunnelKit Automations and select the option to add a new automation. Name this automation something descriptive, like ‘Pabbly Connect Automation’. using Pabbly Connect
Next, select the trigger application as WordPress and set the trigger event to ‘User Created’. Once done, click on the ‘Done’ button to save your settings. You will then be prompted to add a step for the action, which will be sending data to Pabbly Connect.
4. Adding User Data to the Webhook
With the automation set up, you now need to specify the data that will be sent to Pabbly Connect. In the action step, select ‘Send Data to Pabbly Connect’ and paste the webhook URL you copied earlier into the designated field.
- Add fields for email, first name, last name, and username.
- Use merge tags to dynamically insert user data into these fields.
After entering the user details, click on ‘Save’ to finalize your automation. Your FunnelKit setup is now ready to send user data to Pabbly Connect whenever a new user is created.
To ensure everything is working correctly, you need to perform a test submission. Fill in the user details in the provided form and submit it. This action will trigger the webhook and send the data to Pabbly Connect.
Once submitted, check your Pabbly Connect dashboard to confirm that the user details have been received. If successful, you will see the new user data captured, confirming that the integration is working as intended.
Furthermore, you can extend this integration by adding actions to send the captured data to Google Sheets or other applications as needed. This flexibility highlights the power of using Pabbly Connect for seamless integrations.
In this tutorial, we explored how to set up a webhook inside FunnelKit using Pabbly Connect. By following these steps, you can automate user data transfers between FunnelKit and other applications, enhancing your workflow efficiency.
