Learn how to set up a webhook inside Formsite with Pabbly Connect for seamless data integration and automation. Follow our step-by-step guide to streamline your processes.
1. Understanding Webhooks and Pabbly Connect
In this section, we will explore how to set up a webhook inside Formsite using Pabbly Connect. A webhook acts as a bridge to connect applications, delivering data when an event occurs. With Formsite, you can automate data transfer effortlessly.
Utilizing Pabbly Connect allows you to seamlessly integrate Formsite with other applications. This integration enables you to receive form submissions automatically and process them in real-time, enhancing your workflow efficiency.
2. Setting Up Pabbly Connect for Formsite Integration
To begin the integration process, access your Pabbly Connect account. In your dashboard, locate the trigger window where you will select Formsite as your trigger application. The trigger event should be set to ‘New Form Result’.
  • Search for Formsite in the trigger application list.
  • Select ‘New Form Result’ as the trigger event.
  • Copy the provided webhook URL for later use.
This URL is crucial as it will connect your Formsite account with Pabbly Connect. Make sure to note it down for the next steps in the integration process.
3. Configuring Formsite to Use the Webhook
Now, navigate to your Formsite account dashboard. Find the form you created, which we will use for this integration. Click on the ‘Settings’ option, followed by ‘Integrations’ to set up the webhook.
Within the Integrations section, choose ‘Server Post’ and click on the ‘Edit’ button. Enable the integration and paste the webhook URL you copied from Pabbly Connect into the server URL field.
  • Enable the integration by toggling the option.
  • Set the message format to JSON.
  • Click ‘Save’ to apply the changes.
Once saved, you will see a confirmation message indicating that the webhook has been successfully added to your form. This step completes the setup of webhook inside Formsite using Pabbly Connect.
4. Testing the Webhook Integration
To ensure everything is functioning correctly, it’s time to test the integration. Share the link to your Formsite form and fill in the required details to submit a test entry.
After submitting the form, return to your Pabbly Connect dashboard. You should see that it is now waiting for the webhook response. This indicates that the data from your Formsite submission is being sent to Pabbly Connect.
Fill in the test form with sample data. Click on ‘Submit’ to send the data. Check Pabbly Connect for the captured response.
If successful, you will see the details of your submission recorded in both Formsite and Pabbly Connect. This confirms that the integration is working as intended.
5. Conclusion
In this tutorial, we demonstrated how to set up a webhook inside Formsite using Pabbly Connect. This integration allows for seamless data transfer and automation of your form submissions, enhancing your operational efficiency. By following the steps outlined, you can effectively automate your workflows.
Implementing this integration not only saves time but also ensures that your data is processed in real-time, providing a streamlined experience for both you and your users.
