Learn how to set up a webhook inside Formium using Pabbly Connect. This tutorial covers the exact steps to integrate your form submissions seamlessly. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Introduction to Formium and Pabbly Connect
In this section, we will discuss how Pabbly Connect integrates with Formium to automate form submissions. Formium is an online form builder that simplifies data collection through its drag-and-drop interface. By using Pabbly Connect, you can seamlessly capture responses from your forms and manage them efficiently.
Formium allows you to create various types of forms for different purposes, such as surveys and registrations. With Pabbly Connect, you can enhance the functionality of your forms by connecting them to other applications, ensuring that data flows smoothly from Formium to your preferred tools.
2. Setting Up Pabbly Connect for Formium Integration
To start the integration process, access your Pabbly Connect account. You will see two main windows: one for the trigger and another for the action. The trigger is essential as it defines the event that initiates the workflow.
Begin by selecting Formium as your trigger application. For the trigger event, choose ‘REST API – Form Submission.’ This setup ensures that every time a form is submitted on Formium, Pabbly Connect captures the response. Follow these steps:
  • Log into your Pabbly Connect account.
  • Select Formium as the trigger application.
  • Choose ‘REST API – Form Submission’ as the trigger event.
Once the trigger is set, Pabbly Connect will provide you with a webhook URL. This URL acts as a bridge between Formium and Pabbly Connect, allowing it to capture the data from form submissions.
3. Connecting Formium to Pabbly Connect
After obtaining the webhook URL from Pabbly Connect, log into your Formium account. Select the form you wish to connect, and navigate to the workflows section. Here’s how to set it up:
In the workflows section, create a new webhook by clicking on the ‘Create’ button. You will need to provide a name for your webhook and paste the URL from Pabbly Connect. Additionally, set the trigger event to ‘New Submission’ to ensure that the webhook activates whenever a form is submitted. Follow these steps:
  • Navigate to the workflows section in Formium.
  • Click on ‘Create’ to add a new webhook.
  • Paste the Pabbly Connect webhook URL and name your webhook.
  • Set the trigger event to ‘New Submission.’
Once the webhook is created, Pabbly Connect will be ready to capture any new submissions from your Formium forms.
To ensure that the integration is working correctly, perform a test submission on the Formium form you connected to Pabbly Connect. Fill in the required fields like first name, last name, email, and phone number, then submit the form.
After submitting, return to your Pabbly Connect dashboard. You should see that the webhook has captured the response from the test submission. Verify the captured data to ensure everything is functioning as expected. Follow these steps:
Open the form you created in Formium. Fill out the form with test data. Submit the form and check Pabbly Connect for the response.
Once you confirm that Pabbly Connect has captured the data accurately, you can proceed to set up additional actions, such as sending notifications to Slack or storing data in Google Sheets.
5. Conclusion
This tutorial has shown you how to set up a webhook inside Formium using Pabbly Connect. By following the steps outlined, you can automate your form submissions and streamline your data management process. With Pabbly Connect, integrating Formium with other applications is seamless and efficient.
Utilizing Pabbly Connect allows you to enhance your workflow by connecting multiple applications, ensuring that your data is handled effectively. Start automating your processes today!
