Learn how to set up a webhook inside FormDesigner using Pabbly Connect. This step-by-step guide ensures accurate integration for seamless data transfer. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Setting Up Pabbly Connect to Use Webhook
To set up a webhook inside FormDesigner, start by accessing Pabbly Connect. This platform acts as a bridge to connect FormDesigner with other applications, allowing for seamless data transfer.
Begin by navigating to your Pabbly Connect dashboard. Here, you will initiate the creation of a new workflow. Select FormDesigner as your trigger application, and choose the event as ‘New Submission’. This means every time a form submission occurs, Pabbly Connect will capture the data.
2. Copying the Webhook URL from Pabbly Connect
After setting the trigger event, Pabbly Connect generates a unique webhook URL. This URL is crucial as it will connect your FormDesigner account to Pabbly Connect. using Pabbly Connect
Make sure to copy this webhook URL. You will need to paste it into your FormDesigner account. This step is essential for ensuring that data flows from FormDesigner to Pabbly Connect.
3. Configuring FormDesigner to Use the Webhook
Next, go to your FormDesigner dashboard. Here, locate the form you wish to connect and navigate to the ‘Applications’ tab. Scroll down to find the ‘Webhooks’ option.
Click on the ‘ADD’ button to create a new webhook. In the URL field, paste the webhook URL you copied from Pabbly Connect. Select the data transfer method as ‘POST’, since you are sending data from the form submission.
- Enter the parameter for Full Name
- Add another parameter for Email
- Finally, add the parameter for Phone Number
Once all parameters are added, click on ‘Save’. This action successfully establishes the connection between FormDesigner and Pabbly Connect.
4. Testing the Webhook Integration
Now that the webhook is set up, it’s time to test the integration. Go back to your form in FormDesigner and fill it out with test data. Make sure to include details such as a dummy name, email, and phone number. using Pabbly Connect
After submitting the form, you should see a confirmation message indicating the submission was successful. Check your Pabbly Connect dashboard to see if the data has been received. This confirms that the webhook is functioning correctly.
5. Conclusion: Successful Webhook Setup
By following these steps, you have successfully set up a webhook inside FormDesigner using Pabbly Connect. This integration allows for real-time data transfer, enhancing your workflow efficiency.
Whenever a new submission is made, Pabbly Connect captures the details instantly. This seamless connection between FormDesigner and Pabbly Connect empowers you to automate your processes effectively.
In summary, setting up a webhook inside FormDesigner with Pabbly Connect enables efficient data transfer and automation. This guide provides a clear pathway for implementing this integration successfully.
