Learn how to set up a webhook inside Fillout using Pabbly Connect to automate data transfer between applications seamlessly. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Introduction to Pabbly Connect for Webhooks
Pabbly Connect is the central platform that enables seamless integration between Fillout and other applications. In this tutorial, we will learn how to set up a webhook inside Fillout using Pabbly Connect. This process allows you to automate data transfer whenever a form is submitted.
Fillout is a powerful form builder that helps collect data effectively. By using Pabbly Connect, you can ensure that all submissions from Fillout are captured and sent to your desired applications automatically.
2. Setting Up the Webhook in Fillout
To set up the webhook, first, log into your Fillout account. Once logged in, you will see the form you created. If you haven’t created a form yet, you can do so by dragging and dropping the fields you want.
After completing your form, navigate to the Integrations section. Here, you will look for the webhook option. Follow these steps:
  • Go to the Integrations tab in your Fillout dashboard.
  • Search for the webhook option and select it.
  • Paste the webhook URL you copied from Pabbly Connect.
Once you paste the URL, click on the finish setup button. This action will establish a connection between Fillout and Pabbly Connect.
3. Testing the Webhook Connection
After setting up the webhook, it’s crucial to test the connection. In the Fillout dashboard, you will find a test button available next to the webhook configuration. Click this button to send a test submission.
Upon clicking the test button, you should see a response captured in Pabbly Connect. This response confirms that the connection is successful. You can verify the details such as submission time, ID, and the information filled out in the form.
4. Submitting a Form to Capture Data
Now that your webhook is set up and tested, you can go ahead and submit a real form to see the automation in action. Open the shared link of your Fillout form in a new tab. Fill out the form with dummy data, such as name, email, and phone number.
Once you submit the form, return to Pabbly Connect to observe the captured response. You will see all the submitted details, confirming that your integration is functioning correctly. This automation allows you to collect leads efficiently.
5. Using Pabbly Connect for Further Integrations
With the webhook successfully set up, you can now integrate additional applications through Pabbly Connect. For example, you can send the captured data to Google Sheets, Slack, or even WhatsApp.
To do this, simply add the action steps in Pabbly Connect after your webhook trigger. This flexibility allows you to automate various workflows based on the data collected from Fillout.
In conclusion, setting up a webhook inside Fillout using Pabbly Connect is a straightforward process that enables seamless data automation. By following the steps outlined in this tutorial, you can efficiently manage data transfers between Fillout and other applications, enhancing your workflow significantly.
