Learn how to set up a webhook inside ConvertBox using Pabbly Connect. This detailed tutorial covers every step for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Webhook Inside ConvertBox with Pabbly Connect
In this section, we will discuss how to set up a webhook inside ConvertBox using Pabbly Connect. A webhook acts as a bridge to connect applications and deliver data as events occur. This integration allows you to enhance website engagement and conversions effectively.
To begin the setup, access your Pabbly Connect dashboard. Search for ConvertBox in the trigger application section. Select the trigger event as ‘New Lead Submission,’ which will activate whenever a new lead is created in your ConvertBox account.
2. Copying the Webhook URL from Pabbly Connect
Once you have selected the trigger event in Pabbly Connect, a webhook URL will be generated. This URL is crucial as it connects your ConvertBox account with Pabbly Connect. Make sure to read the help text provided to understand how to use this URL effectively.
After copying the webhook URL, navigate to your ConvertBox account. Here’s how to proceed:
  • Log into your ConvertBox account.
  • Go to the dashboard and select the ConvertBox you want to edit.
  • Click on ‘Edit’ and then navigate to the ‘Form Settings’ section.
In the form settings, click on the ‘Integrations’ tab and then on the plus sign to add an integration. Choose ‘Webhooks’ as your integration type and paste the copied webhook URL into the designated field.
3. Testing the Webhook Setup
Testing the webhook setup is essential to ensure that data is being sent correctly from ConvertBox to Pabbly Connect. After pasting the webhook URL, you will have the option to send test data. Click on ‘Send Test’ to initiate this process.
Once the test data is sent, return to Pabbly Connect to verify that the response has been received. If successful, you will see the test data captured, indicating that the webhook setup is functioning correctly. Follow these steps to complete the testing:
  • Click on ‘Send Test’ in ConvertBox.
  • Check Pabbly Connect for the test response.
  • Confirm that the test data appears correctly in Pabbly Connect.
Upon successful testing, proceed to save the integration settings in ConvertBox.
4. Finalizing the Integration in ConvertBox
After successfully testing the webhook, it’s time to finalize the integration within ConvertBox using Pabbly Connect. Click on the ‘Save’ button to ensure all changes are recorded. You will then see a confirmation message stating that your changes have been saved successfully.
To complete your setup, navigate through the next steps in ConvertBox, confirming each option until you reach the finish button. This process ensures that your webhook is fully integrated and ready to capture new leads automatically.
5. Capturing New Leads with Pabbly Connect
With the webhook successfully set up, every time a new lead is generated in your ConvertBox account, the details will be automatically sent to Pabbly Connect. This allows for seamless data management and integration with other applications.
To capture new leads, perform a test submission on your ConvertBox form. Fill in the required fields such as first name, last name, email, and phone number, and click submit. After submission, check Pabbly Connect for the captured lead details.
In Pabbly Connect, you will see all the lead information, including:
First Name Last Name Email Address Phone Number City and State
This data can now be used for further automation or integration with other applications through Pabbly Connect.
Setting up a webhook inside ConvertBox using Pabbly Connect allows for efficient lead management and integration. By following the detailed steps provided, you can ensure that your new leads are captured seamlessly and effectively.
