Learn how to set up a webhook inside Agiled using Pabbly Connect to automate contact creation and data management seamlessly. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Setting Up Pabbly Connect for Agiled Integration
To set up a webhook inside Agiled, start by accessing Pabbly Connect. This platform allows you to create connections between various applications, including Agiled, to automate your workflows efficiently.
Begin by logging into your Pabbly Connect account. Once logged in, navigate to the ‘Triggers’ section where you will set Agiled as your trigger application. This action is crucial for initiating the integration process.
2. Selecting the Trigger Event in Pabbly Connect
In this step, you will select the trigger event in Pabbly Connect. Search for Agiled in the trigger application field and select it. The specific trigger event you want to choose is ‘New Contact.’ This event will activate whenever a new contact is added in Agiled.
  • Search for Agiled in the trigger application list.
  • Select the ‘New Contact’ trigger event.
After selecting the trigger event, you will receive a webhook URL. This URL acts as a bridge connecting Agiled with Pabbly Connect. Make sure to copy this URL as it is essential for the next steps.
3. Creating a Webhook in Agiled
Now, switch to your Agiled account. Navigate to the ‘Settings’ section and find the ‘Custom Webhooks’ option. This is where you will set up the webhook that connects to Pabbly Connect.
In the Custom Webhooks section, create a new webhook. Paste the webhook URL you copied from Pabbly Connect into the designated field. Make sure to select the same trigger event, which is ‘Contact Creation,’ to ensure consistency between Agiled and Pabbly Connect.
With the webhook now created, it’s time to test the integration. Go back to your Pabbly Connect dashboard and initiate a test submission. This can be done by filling out the contact form you created in Agiled.
For the test, enter the first name, last name, email address, and a dummy mobile number. After submitting the form, check both Agiled and Pabbly Connect to confirm that the new contact was created and that the details were captured correctly.
  • Fill out the contact form in Agiled.
  • Submit the form to create a new contact.
  • Verify that the details appear in Pabbly Connect.
Upon successful submission, you should see the new contact details reflected in both your Agiled account and Pabbly Connect, confirming that the integration is working smoothly.
5. Conclusion
In this tutorial, we learned how to set up a webhook inside Agiled using Pabbly Connect. By following the steps outlined, you can automate contact creation and manage your data efficiently. This integration enhances your operational workflow significantly.
With Pabbly Connect, you can connect various applications and create seamless automations, improving productivity for your business operations.
